ChainElement represents individual links, buckets, or carriers in continuous chain transport systems. More...
| void | InitPos (float pos) |
| void | SetPosition () |
| void | UpdatePosition (float deltaTime) |
| void | UpdatePosition (Drive drive) |
| void | UpdatePositionBatch (float position) |
| bool | AlignWithChain |
| true if the chainelement needs to align with the chain tangent while moving | |
| bool | MoveRigidBody |
| needs to be set to true if chainelements has colliders which should make parts move physically | |
| Vector3 | AlignVector |
| additinal rotation for the alignment | |
| GameObject | AlignObjectLocalZUp |
| bool | DebugDirections |
| float | InitialPosition |
| float | OffsetToDrivePosition |
| Chain | ConnectedChain |
| bool | UseBatchUpdate |
Properties | |
| Drive | ConnectedDrive [get, set] |
| Drive where the chain is connected to. | |
| float | StartPosition [get, set] |
| Start position of this chain element. | |
| Chain | Chain [get, set] |
| Chain where this chainelement belongs to. | |
| bool | UsePath [get, set] |
| bool | UseUnitySpline [get, set] |
| float | Position [get, set] |
| Current position of this chain element. | |
| float | RelativePosition [get, set] |
| Relative position of this chain element. | |
Properties inherited from realvirtual.IChainElement | |
This component transforms objects into chain-driven transport elements that move along spline paths, maintaining proper spacing and orientation while transporting materials. Supports automatic alignment with chain curvature, physics-based collision handling for material interaction, and synchronization with drive speeds. Essential for bucket elevators, overhead power-and-free systems, chain conveyors, and other continuous transport applications in manufacturing and material handling.
◆ InitPos()
| void realvirtual.ChainElement.InitPos | ( | float | pos | ) |
Implements realvirtual.IChainElement.
◆ AlignVector
| Vector3 realvirtual.ChainElement.AlignVector |
◆ AlignWithChain
| bool realvirtual.ChainElement.AlignWithChain |
◆ MoveRigidBody
| bool realvirtual.ChainElement.MoveRigidBody |
Property Documentation
◆ Chain
getset |
◆ ConnectedDrive
getset |
◆ Position
getset |
◆ RelativePosition
getset |
◆ StartPosition
getset |
◆ UsePath
getset |
◆ UseUnitySpline
getset |
