Chain component creates continuous loop transport systems with elements following spline-defined paths in industrial automation. More...
| void | OnXRInit (GameObject placedobj) |
| Initializes the chain for XR/AR placement. | |
| void | OnXRStartPlace (GameObject placedobj) |
| Invalidates Burst data when placement begins to prevent stale world-space positions. | |
| void | OnXREndPlace (GameObject placedobj) |
| Re-initialization happens automatically on next drive event after placement ends. | |
| void | Modify () |
| Vector3 | GetPosition (float normalizedposition) |
| Vector3 | GetTangent (float normalizedposition) |
| Vector3 | GetUpDirection (float normalizedposition) |
| void | RegisterElement (ChainElement element) |
| void | UnregisterElement (ChainElement element) |
| bool | _burstSetupInfo |
| ChainOrientation | chainOrientation |
| Orientation of the chain (Horizontal or Vertical) | |
| GameObject | ChainElement |
| Chainelements which needs to be created along the chain. | |
| string | NameChainElement |
| Name for the chain elements. | |
| Drive | ConnectedDrive |
| The drive which is moving this chain. | |
| int | NumberOfElements |
| The number of elements which needs to be created along the chain. | |
| float | StartPosition |
| The start position in millimeters on the chain (offset) for the first element. | |
| bool | CreateElementeInEditMode |
| Create chain elements in edit mode. | |
| bool | CalculatedDeltaPosition |
| True if the distance (DeltaPosition) between the chain elements should be calculated based on number and chain length. | |
| float | DeltaPosition |
| Distance in millimeters between chain elements. | |
| bool | ScaledOnFixedLength |
| Scale chain to fixed length. | |
| float | FixedLength |
| Fixed chain length in millimeters. | |
| float | DriveUpdateThreshold |
| float | ElementUpdateThreshold |
| float | Length |
| The calculated length of the spline in millimeters. | |
| SplineContainer | splineContainer |
| bool | unitySplineActive |
| bool | usepath |
| List< ChainElement > | chainElements |
| bool | UseBurstOptimization |
| override void | AfterAwake () |
The Chain component is designed for simulating chain-driven transport systems where individual elements (links, buckets, carriers, or fixtures) move along a continuous path. It automatically generates and positions chain elements along spline curves, providing realistic visualization and physics simulation of chain conveyors, bucket elevators, overhead conveyors, and similar transport mechanisms.
Key features:
- Automatic generation of chain elements along spline paths
- Unity Splines backend for spline path definition
- Configurable element spacing with automatic or manual distribution
- Horizontal and vertical chain orientations for different applications
- Edit-mode preview for design-time visualization
- Integration with Drive components for speed control
- Scalable chain length with automatic element adjustment
- Support for complex 3D paths including curves and elevation changes
Common applications in industrial automation:
- Chain conveyors for heavy-duty material transport
- Bucket elevators for vertical material handling
- Overhead power and free conveyors in assembly lines
- Carousel systems for buffering and accumulation
- Pallet transport systems with carriers
- Drag chain conveyors for bulk material
- Accumulating chain conveyors with individual carriers
- Festoon systems for cable management
The Chain component works by:
- Analyzing the spline path to calculate total length
- Generating specified number of elements at calculated intervals
- Positioning each element along the spline based on normalized position
- Updating element positions based on drive speed during simulation
- Maintaining proper orientation along the path tangent
Chain element types and configurations:
- Simple chain links for basic visualization
- Buckets for bucket elevator simulation
- Carriers with fixtures for workpiece transport
- Pallets for automated storage systems
- Custom prefabs for specialized applications
Integration with other components:
- Requires IChain interface implementation (ChainUnitySpline)
- Connects to Drive component for movement control
- Chain elements implement IChainElement for position updates
- Works with sensors for element detection
- Compatible with MU components for load handling
- Can trigger events based on element positions
Path definition options:
- Unity Splines (SplineContainer) for advanced curve control
- Support for closed loops and open-ended paths
- Multiple spline segments for complex routing
- Tangent and normal control for element orientation
Performance considerations:
- Element count affects performance - optimize for visible detail
- Use simplified meshes for chain elements when possible
- Consider LOD systems for large chain installations
- Batch element updates for better performance
- Use appropriate update rates based on chain speed
The Chain component provides essential functionality for industries requiring continuous material flow along defined paths, offering both visual accuracy and functional simulation capabilities.
For detailed documentation and examples, see: https://doc.realvirtual.io/components-and-scripts/motion/chain
◆ AfterAwake()
protectedvirtual |
◆ OnXREndPlace()
| void realvirtual.Chain.OnXREndPlace | ( | GameObject | placedobj | ) |
IMPLEMENTS IXRPlaceable::OnXREndPlace
◆ OnXRInit()
| void realvirtual.Chain.OnXRInit | ( | GameObject | placedobj | ) |
IMPLEMENTS IXRPlaceable::OnXRInit
◆ OnXRStartPlace()
| void realvirtual.Chain.OnXRStartPlace | ( | GameObject | placedobj | ) |
IMPLEMENTS IXRPlaceable::OnXRStartPlace
◆ CalculatedDeltaPosition
| bool realvirtual.Chain.CalculatedDeltaPosition |
◆ ChainElement
| GameObject realvirtual.Chain.ChainElement |
◆ chainOrientation
| ChainOrientation realvirtual.Chain.chainOrientation |
◆ ConnectedDrive
| Drive realvirtual.Chain.ConnectedDrive |
◆ CreateElementeInEditMode
| bool realvirtual.Chain.CreateElementeInEditMode |
◆ DeltaPosition
| float realvirtual.Chain.DeltaPosition |
◆ FixedLength
| float realvirtual.Chain.FixedLength |
◆ Length
| float realvirtual.Chain.Length |
◆ NameChainElement
| string realvirtual.Chain.NameChainElement |
◆ NumberOfElements
| int realvirtual.Chain.NumberOfElements |
◆ ScaledOnFixedLength
| bool realvirtual.Chain.ScaledOnFixedLength |
◆ StartPosition
| float realvirtual.Chain.StartPosition |
