CAM component implements electronic cam functionality for synchronized master-slave drive control in automation systems. More...
Classes | |
| class | campoint |
| void | ImportCam () |
| void | CalcFixedUpdate () |
| static float | GetFloat (string value, float defaultValue) |
| Drive | MasterDrive |
| The master drive this slave drive is attached to. | |
| float | MasterDriveAxisScale |
| A scale factor. The master drive position is multiplied with this factor to get the position which is used in the CAM curve. | |
| float | MasterDriveAxisOffset |
| An offset to the master drive. The offset is added to the master drive position to get the position which is used in the CAM curve. | |
| float | CAMAxisScale |
| The scale of the CAM axis. It will scale the values of the CAM curve. | |
| float | CAMAxisOffset |
| The offset of the CAM axis. It will be added to the values of the CAM cure to get the position which is applied to the CAM (slave) axis. | |
| CamFileType | FileType |
| string | ExcelSheet |
| string | ExcelFile |
| AnimationCurve | CamCurve |
| The Animation Curve which is defining the slave drive position in relation to the master drive position. | |
| TextAsset | CamDefintion |
| A text assed containing the CAM definition. This asset is a table with optional headers and columns describing the master axis position and the slave axis position. | |
| bool | UseColumnNames |
| If true the Column Names are used to define the data to import. | |
| string | MasterColumn |
| The master axis column name. | |
| string | SlaveColumn |
| The slave axis column name. | |
| bool | UseColumnNumbers |
| If true the Column Numbers (starting with 1 for the 1st column) are used to define the data to import. | |
| int | MasterColumnNum |
| The master axis column number. | |
| int | SlaveColumnNum |
| The slave axis column number. | |
| bool | CamDefinitionWithHeader |
| if true during import a column header is expected and first line of the imported data should be a header | |
| bool | ImportOnStart |
| bool | IsContinous |
| if true text asset is always imported on simulation start | |
| float | ContinousOffset |
The CAM component provides electronic cam control, allowing a slave drive to follow complex motion profiles based on the position of a master drive. This simulates the behavior of mechanical cam systems digitally, enabling precise, repeatable motion patterns without physical cam mechanisms. The component uses animation curves or imported data tables to define the relationship between master and slave positions.
Key features:
- Position-based synchronization between master and slave drives
- Import cam profiles from Excel or CSV files for easy integration with engineering tools
- Visual animation curve editor for custom motion profiles
- Scaling and offset adjustments for both master and slave axes
- Continuous mode for endless motion patterns (e.g., chain drives)
- Support for complex non-linear relationships and motion interpolation
- Column-based or header-based data import with flexible mapping
- Real-time profile switching and modification capabilities
Common applications in industrial automation:
- Packaging machines with synchronized sealing and cutting operations
- Bottle filling systems with coordinated nozzle and conveyor movement
- Press machines with complex ram motion profiles
- Pick and place robots with optimized acceleration profiles
- Rotary indexing tables with variable speed segments
- Web handling systems with dancer roll compensation
- Flying shear applications with speed matching
- Labeling machines with product tracking
The CAM profile defines how the slave axis position changes relative to the master axis position. This enables complex motion patterns such as:
- Dwell periods where slave remains stationary while master moves
- Quick return strokes with different forward and return speeds
- Smooth acceleration and deceleration profiles
- Multiple motion segments with different characteristics
- Cyclic patterns for continuous operation
Integration with other components:
- Requires connection to master Drive component for position input
- Acts as a behavior on slave Drive component
- Can be combined with other drive behaviors for complex control
- Works with PLCInputFloat/PLCOutputFloat for dynamic parameter adjustment
- Compatible with drive limits and safety functions
Data import capabilities:
- Excel files with configurable sheet and column selection
- CSV files with header or column number mapping
- Automatic curve generation from imported data points
- Support for engineering units and scaling factors
- Preview and validation of imported profiles
Performance considerations:
- CAM evaluation happens in FixedUpdate for deterministic behavior
- Interpolation between curve points ensures smooth motion
- Continuous mode handles wraparound for endless applications
- Efficient curve evaluation using Unity's AnimationCurve system
The CAM component is essential for applications requiring precise coordination between multiple axes, replacing traditional mechanical cams with flexible electronic control.
For detailed documentation and examples, see: https://doc.realvirtual.io/components-and-scripts/motion/cam
Class Documentation
◆ realvirtual::CAM::campoint
◆ CalcFixedUpdate()
| void realvirtual.CAM.CalcFixedUpdate | ( | ) |
◆ CAMAxisOffset
| float realvirtual.CAM.CAMAxisOffset |
◆ CAMAxisScale
| float realvirtual.CAM.CAMAxisScale |
◆ CamCurve
| AnimationCurve realvirtual.CAM.CamCurve |
◆ CamDefinitionWithHeader
| bool realvirtual.CAM.CamDefinitionWithHeader |
◆ CamDefintion
| TextAsset realvirtual.CAM.CamDefintion |
◆ IsContinous
| bool realvirtual.CAM.IsContinous |
If set to true the CAM will continue as an offset based on the the last CAM position, for example for continous positive moving things like transport chains
◆ MasterColumn
| string realvirtual.CAM.MasterColumn |
◆ MasterColumnNum
| int realvirtual.CAM.MasterColumnNum |
◆ MasterDrive
| Drive realvirtual.CAM.MasterDrive |
◆ MasterDriveAxisOffset
| float realvirtual.CAM.MasterDriveAxisOffset |
◆ MasterDriveAxisScale
| float realvirtual.CAM.MasterDriveAxisScale |
◆ SlaveColumn
| string realvirtual.CAM.SlaveColumn |
◆ SlaveColumnNum
| int realvirtual.CAM.SlaveColumnNum |
◆ UseColumnNames
| bool realvirtual.CAM.UseColumnNames |
◆ UseColumnNumbers
| bool realvirtual.CAM.UseColumnNumbers |
