Marks a GameObject as a safety door for the WebViewer 3D-HMI. More...
| float | HazardZoneRadius |
| Halo radius in mm. | |
| float | LabelHeight |
| Label position above floor in mm (low/bottom by default) | |
In the WebViewer, the door is visualized with an amber outline around the door mesh, a translucent floor halo indicating the hazard zone, and a billboard label "SAFETY DOOR — OPEN" above the door. The visualization is overlay-only — the door mesh itself is never recolored, preserving asset identity per ISA-101 HPHMI rules.
This is the demo / v1 component: doors are static and always shown as OPEN. The component is designed to be extended with state machine, PLC signals, drive observation, and aggregated messaging in future releases.
Configuration is exported as rv_extras into the GLB and consumed by the WebViewer's RVSafetyDoor TypeScript component.
◆ HazardZoneRadius
| float realvirtual.WebSafetyDoor.HazardZoneRadius |
Halo radius in mm.
◆ LabelHeight
| float realvirtual.WebSafetyDoor.LabelHeight |
Public Attributes inherited from
