Generates test signal values for the PLCInput signal on this GameObject. More...
| void | RefreshSignal () |
| Discovers the PLCInput signal on this GameObject. | |
| bool | EnableTesting |
| Enable or disable test signal generation. | |
| float | UpdateInterval |
| Time in seconds between signal updates. | |
| float | SineAmplitude |
| Amplitude of the sine wave for float signals in signal units. | |
| float | SineOffset |
| Center offset of the sine wave for float signals. | |
| float | SineFrequency |
| Frequency of the sine wave in Hz. | |
| float | ToggleInterval |
| Time in seconds between bool toggles. | |
| int | IntIncrement |
| Increment value per update cycle for int signals. | |
| int | IntMax |
| Maximum value before int counter resets to zero. | |
| int | CycleCount |
| Number of update cycles completed. | |
| string | DetectedSignalType |
| Type of signal detected on this GameObject. | |
Place this component on a signal GameObject (PLCInputBool, PLCInputFloat, PLCInputInt) to generate cyclic test patterns without a PLC connection. Float signals follow a sine wave, Bool signals toggle on/off, and Int signals increment.
For detailed documentation see: https://doc.realvirtual.io/components-and-scripts/interfaces/signal-test-generator
◆ RefreshSignal()
| void realvirtual.SignalTestGenerator.RefreshSignal | ( | ) |
◆ CycleCount
| int realvirtual.SignalTestGenerator.CycleCount |
◆ DetectedSignalType
| string realvirtual.SignalTestGenerator.DetectedSignalType |
◆ EnableTesting
| bool realvirtual.SignalTestGenerator.EnableTesting |
◆ IntIncrement
| int realvirtual.SignalTestGenerator.IntIncrement |
◆ IntMax
| int realvirtual.SignalTestGenerator.IntMax |
◆ SineAmplitude
| float realvirtual.SignalTestGenerator.SineAmplitude |
◆ SineFrequency
| float realvirtual.SignalTestGenerator.SineFrequency |
◆ SineOffset
| float realvirtual.SignalTestGenerator.SineOffset |
◆ ToggleInterval
| float realvirtual.SignalTestGenerator.ToggleInterval |
◆ UpdateInterval
| float realvirtual.SignalTestGenerator.UpdateInterval |
