Selection Raycast for selecting objects during runtime. More...
| bool | IsOnUIElement () |
| void | SelectObject (GameObject obj) |
| void | DeSelectObject (GameObject obj) |
| void | MultiSelectOn (bool turnon) |
| void | DeSelectObject () |
| void | DeSelectIfNotThis (GameObject obj) |
| Vector3 | GetHitpoint () |
| void | ShowCenterIcon (bool show) |
| bool | AlwaysOn |
| if true the selection is always on even if button is turned off in game4automation controller | |
| bool | IsActive |
| selection by raycast is active | |
| bool | EnableToch |
| allow touch input | |
| bool | AutomaticallyAddColliders |
| bool | ChangeMaterialOnHover |
| change material on hover | |
| bool | EnableMultiSelect |
| enable multi select | |
| Material | HighlightMaterial |
| the highlight materiials | |
| bool | ChangeMaterialOnSelect |
| change material on select | |
| Material | SelectMaterial |
| the select material | |
| List< string > | SelectionLayer |
| the layers that can be selected | |
| string | ContextToolbarLayer |
| the layer for the toolbar - selection will be kept active if toolbar is touched | |
| GameObject | TouchedObject |
| bool | ObjectIsSelected |
| GameObject | SelectedObject |
| the selected object | |
| List< GameObject > | SelectedObjects |
| the selected objects on multiselect | |
| Vector3 | SelectedPosition |
| the selected object hit point position | |
| bool | ObjectIsHovered |
| GameObject | HoveredObject |
| the hovered object | |
| Vector3 | HoveredPosition |
| the hovered object hit point position | |
| bool | MultiSelectModeIsOn |
| bool | DoubleSelect |
| bool | LongPressed |
| bool | OnUI |
| bool | OnContextToolbar |
| true if the object was double clicked | |
| bool | MouseDownOnObject |
| true if the mouse was going down on a selectable object | |
| bool | PingHoverObject |
| true if the hovered object should be pinged in the hierarchy | |
| bool | SelectHoverObject |
| true if the hovered object should be selected in the hierarchy | |
| bool | PingSelectObject |
| true if the selected object should be pinged in the hierarchy | |
| bool | SelectSelectObject |
| true if the selected object should be selected in the hierarchy | |
| bool | AutoCenterSelectedObject |
| true if the selected object (its selection point) is automatically centered in the scene view | |
| bool | ZoomDoubleClickedObject |
| true if the selected object (its selection point) is automatically centered in the scene view when double clicking on it | |
| bool | FocusDoubleClickedObject |
| bool | OpenRuntimeINspector |
| bool | ShowSelectedIcon |
| float | TimeDoubleClick |
| time in seconds for double click | |
| float | TimeLongPress |
| time in seconds for long press | |
| realvirtualEventSelected | EventSelected |
| Unity event which is called for MU enter and exit. On enter it passes MU and true. On exit it passes MU and false. | |
| realvirtualEventHovered | EventHovered |
| realvirtualEventDoubleClicked | EventDoubleClicked |
| realvirtualEventBlockRotation | EventBlockRotation |
| Unity event which is called when rotation should be blocked. | |
| realvirtualEventLongPressed | EventLongPressed |
| realvirtualEventMultiSelect | EventMultiSelect |
| Unity event which is called when rotation should be blocked]. | |
| realvirtualEventMultiSelectEmpty | EventMultiSelectEmpty |
| realvirutalEventMouseDownOnObject | EventMouseDownOnObject |
| Unity event which is called when mouse is down on an object. | |
| RuntimeInspector | RuntimeInspector |
| GameObject | SelectedIcon |
| bool | DebugMode |
| IRaycaster | raycaster |
◆ AlwaysOn
| bool realvirtual.SelectionRaycast.AlwaysOn |
◆ AutoCenterSelectedObject
| bool realvirtual.SelectionRaycast.AutoCenterSelectedObject |
◆ ChangeMaterialOnHover
| bool realvirtual.SelectionRaycast.ChangeMaterialOnHover |
◆ ChangeMaterialOnSelect
| bool realvirtual.SelectionRaycast.ChangeMaterialOnSelect |
◆ ContextToolbarLayer
| string realvirtual.SelectionRaycast.ContextToolbarLayer |
◆ EnableMultiSelect
| bool realvirtual.SelectionRaycast.EnableMultiSelect |
enable multi select
◆ EnableToch
| bool realvirtual.SelectionRaycast.EnableToch |
allow touch input
◆ EventBlockRotation
| realvirtualEventBlockRotation realvirtual.SelectionRaycast.EventBlockRotation |
◆ EventDoubleClicked
| realvirtualEventDoubleClicked realvirtual.SelectionRaycast.EventDoubleClicked |
◆ EventHovered
| realvirtualEventHovered realvirtual.SelectionRaycast.EventHovered |
◆ EventLongPressed
| realvirtualEventLongPressed realvirtual.SelectionRaycast.EventLongPressed |
◆ EventMouseDownOnObject
| realvirutalEventMouseDownOnObject realvirtual.SelectionRaycast.EventMouseDownOnObject |
◆ EventMultiSelect
| realvirtualEventMultiSelect realvirtual.SelectionRaycast.EventMultiSelect |
◆ EventMultiSelectEmpty
| realvirtualEventMultiSelectEmpty realvirtual.SelectionRaycast.EventMultiSelectEmpty |
◆ EventSelected
| realvirtualEventSelected realvirtual.SelectionRaycast.EventSelected |
◆ FocusDoubleClickedObject
| bool realvirtual.SelectionRaycast.FocusDoubleClickedObject |
◆ HighlightMaterial
| Material realvirtual.SelectionRaycast.HighlightMaterial |
◆ HoveredObject
| GameObject realvirtual.SelectionRaycast.HoveredObject |
the hovered object
◆ HoveredPosition
| Vector3 realvirtual.SelectionRaycast.HoveredPosition |
◆ IsActive
| bool realvirtual.SelectionRaycast.IsActive |
◆ MouseDownOnObject
| bool realvirtual.SelectionRaycast.MouseDownOnObject |
◆ OnContextToolbar
| bool realvirtual.SelectionRaycast.OnContextToolbar |
◆ PingHoverObject
| bool realvirtual.SelectionRaycast.PingHoverObject |
◆ PingSelectObject
| bool realvirtual.SelectionRaycast.PingSelectObject |
◆ SelectedObject
| GameObject realvirtual.SelectionRaycast.SelectedObject |
the selected object
◆ SelectedObjects
| List<GameObject> realvirtual.SelectionRaycast.SelectedObjects |
◆ SelectedPosition
| Vector3 realvirtual.SelectionRaycast.SelectedPosition |
◆ SelectHoverObject
| bool realvirtual.SelectionRaycast.SelectHoverObject |
◆ SelectionLayer
| List<string> realvirtual.SelectionRaycast.SelectionLayer |
◆ SelectMaterial
| Material realvirtual.SelectionRaycast.SelectMaterial |
the select material
◆ SelectSelectObject
| bool realvirtual.SelectionRaycast.SelectSelectObject |
◆ TimeDoubleClick
| float realvirtual.SelectionRaycast.TimeDoubleClick |
◆ TimeLongPress
| float realvirtual.SelectionRaycast.TimeLongPress |
◆ ZoomDoubleClickedObject
| bool realvirtual.SelectionRaycast.ZoomDoubleClickedObject |
