Controls the Mouse and Touch navigation in Game mode. More...
| delegate void | StartStopCameraInterpolation (bool start) |
| delegate for starting and stopping camera interpolation | |
| delegate void | StartStopPanning (bool start) |
| delegate for starting and stopping panning | |
| delegate void | StartStopRotation (bool start) |
| Delegates for Events delegate for starting and stopping rotation. | |
| void | OnButtonOrthoOverlay (GenericButton button) |
| is called when orthographic overlay views button is pressed in the main menu bar | |
| void | OrthoOverlayToggleOn () |
| void | OrthoOverlayToggleOff () |
| void | OnButtonOrthographicView (GenericButton button) |
| is called when orthographic view is enabled or disabled | |
| void | OrthographicViewToggleOn () |
| void | OrthographicViewToggleOff () |
| void | SetOrthographicView (bool active) |
| void | BlockRotation (bool block, bool onlyleftmouse) |
| Blocks the rotation of the camera e.g. when an element is selected with left mouse and left mouse rotation is on. | |
| void | OnViewButton (GenericButton button) |
| called by main menu view button to switch between first person controller and normal mouse navigation | |
| void | ViewButtonToggleOn () |
| void | ViewButtonToggleOff () |
| void | SetNewCameraPosition (Vector3 targetpos, float camdistance, Vector3 camrotation, bool nointerpolate=false) |
| sets a new camera position based ob targetos, distance to targetois and rotation | |
| void | SetViewDirection (Vector3 camrotation) |
| sets the camera view direction based on a vector | |
| void | FocusOnObjects (List< GameObject > objectsToFocus, float paddingFactor=1.2f) |
| Performs a one-time camera movement to focus on multiple GameObjects. | |
| void | FocusOnObject (GameObject objectToFocus, float? distance=null, Vector3? viewAngle=null) |
| Performs a one-time camera movement to focus on the specified GameObject. | |
| void | StartFollowing (GameObject objectToFollow, float? distance=null, Vector3? viewAngle=null, bool allowRotation=false, bool allowZoom=false, float lerpSpeed=1.0f, bool smoothStart=true, bool stopOnMouseClick=false) |
| Starts continuous camera following of the specified GameObject. | |
| void | StartRidingTransform (GameObject objectToRide, float lerpSpeed=5.0f, bool smoothStart=true, bool stopOnMouseClick=false) |
| Starts "riding" an object's transform - camera position AND rotation match the followed object. | |
| void | StartFollowingObjects (List< GameObject > objectsToFollow, float paddingFactor=1.2f, bool allowRotation=false, bool allowZoom=false, float lerpSpeed=1.0f, bool smoothStart=true, bool stopOnMouseClick=false) |
| Starts continuous camera following of multiple GameObjects. | |
| void | StopFollowing () |
| Stops continuous camera following of the currently tracked object. | |
| void | ActivateCinemachine (bool activate) |
| void | Init () |
| bool | UseOrbitCameraMode |
| Toggle the orbit camera mode. | |
| bool | FirstPersonControllerActive |
| Toggle the first person controller. | |
| bool | RotateWithLeftMouseButton |
| Rotate the camera with the left mouse button. | |
| bool | RotateToFocusObject |
| Rotates the camera to focused objects instead of panning the camera. | |
| bool | BlockRotationOnSelected |
| FirstPersonController | FirstPersonController |
| Reference to the first person controller script. | |
| CameraPos | LastCameraPosition |
| The last camera position before switching modes. | |
| bool | SetCameraPosOnStartPlay |
| Set the camera position on start play. | |
| bool | SaveCameraPosOnQuit |
| Save the camera position on quitting the application. | |
| bool | SetEditorCameraPos |
| Set the editor camera position. | |
| bool | InterpolateToNewCamerapoitions |
| Interpolate to new saved Camerapositions. | |
| float | CameraInterpolationSpeed |
| Interpolation speed to new saved Camerapositions. | |
| Transform | target |
| The target of the camera. | |
| Vector3 | targetOffset |
| Offset of the camera's target. | |
| float | distance |
| The distance of the camera from its target. | |
| float | DPIScale |
| The DPI scale of the screen, is automatically calculated and is used to scale all screen pixel related distances measurements. | |
| float | minDistance |
| The minimum distance of the camera from its target. | |
| float | MouseRotationSpeed |
| The speed of rotation around the y-axis. | |
| float | MasterSensitivity |
| Master sensitivity multiplier affecting all navigation speeds. | |
| float | MinHorizontalRotation |
| The minimum angle limit for the camera rotation around the x-axis. | |
| float | MaxHorizontalRotation |
| The maximum angle limit for the camera rotation around the x-axis. | |
| float | ZoomSpeed |
| The speed of zooming in and out, 1 is standard. | |
| float | RotDamping |
| The speed at which the zooming slows down, 1 is standard. | |
| float | PanDamping |
| The speed at which the panning slows down, 1 is standard. | |
| float | CursorSpeed |
| float | ZoomDamping |
| float | orthoPanSpeed |
| The speed of panning the camera in orthographic mode. | |
| float | StartDemoOnInactivity |
| The time to wait before starting the demo due to inactivity. | |
| float | DurationNoMouseActivity |
| The time without any mouse activity before considering the camera inactive. | |
| GameObject | DebugObj |
| TouchInteraction | Touch |
| The touch interaction script. | |
| float | TouchPanSpeed |
| The speed of rotating with touch. | |
| float | TouchRotationSpeed |
| float | TouchZoomSpeed |
| The speed of zooming with touch. | |
| bool | TouchInvertVertical |
| bool | TouchInvertHorizontal |
| Touch invert vertical. | |
| bool | EnableSpaceNavigator |
| Touch invert horizontal. | |
| float | SpaceNavTransSpeed |
| Enable space navigator. | |
| float | currentDistance |
| Space navigator translation speed. | |
| float | desiredDistance |
| Current distance. | |
| Quaternion | currentRotation |
| Desired distance. | |
| Quaternion | desiredRotation |
| Current rotation. | |
| bool | isRotating |
| Desired rotation. | |
| bool | isPanning |
| bool | interpolatingToNewCameraPos |
| bool | CinemachineIsActive |
| bool | blockrotation |
| bool | blockleftmouserotation |
| bool | orthograhicview |
| OrthoViewController | orthoviewcontroller |
| StartStopCameraInterpolation | EventStartStopCameraInterpolation |
| StartStopPanning | EventStartStopPanning |
| StartStopRotation | EventStartStopRotation |
| float | FollowBoundsSmoothTime |
Properties | |
| bool | IsRiding [get] |
| Returns true if the camera is currently "riding" an object's transform (matching position and rotation). | |
| bool | IsFollowing [get] |
| Returns true if the camera is currently in follow mode, tracking an object. | |
| GameObject | FollowedObject [get] |
| Returns the GameObject currently being followed, or null if not in follow mode. | |
◆ BlockRotation()
| void realvirtual.SceneMouseNavigation.BlockRotation | ( | bool | block, |
| bool | onlyleftmouse | ||
◆ FocusOnObject()
| void realvirtual.SceneMouseNavigation.FocusOnObject | ( | GameObject | objectToFocus, |
| float? | distance = null, |
| Vector3? | viewAngle = null |
The camera will smoothly move to view the object but will not continuously track it if it moves. Uses the object's pivot point for positioning, bounds only for distance calculation.
Example usage:
- FocusOnObject(robot) - Auto-calculates distance to fit object at 1/3 screen space
- FocusOnObject(conveyor, distance: 5.0f) - Focus with specific distance
- FocusOnObject(sensor, distance: 2.5f, viewAngle: new Vector3(45, 90, 0)) - With specific angle
◆ FocusOnObjects()
| void realvirtual.SceneMouseNavigation.FocusOnObjects | ( | List< GameObject > | objectsToFocus, |
| float | paddingFactor = 1::2f |
The camera will smoothly move to view all objects in the list but will not continuously track them. Calculates combined bounds of all objects and positions camera to fit all objects in view.
Parameters:
- objectsToFocus: List of GameObjects to focus on (required, must not be empty)
- paddingFactor: Multiplier for extra padding around combined bounds (default 1.2 = 20% padding)
Example usage:
- FocusOnObjects(selectedParts) - Focus on list of parts with default padding
- FocusOnObjects(conveyors, 1.5f) - Focus with 50% extra padding for more breathing room
◆ OnButtonOrthographicView()
| void realvirtual.SceneMouseNavigation.OnButtonOrthographicView | ( | GenericButton | button | ) |
◆ OnButtonOrthoOverlay()
| void realvirtual.SceneMouseNavigation.OnButtonOrthoOverlay | ( | GenericButton | button | ) |
◆ OnViewButton()
| void realvirtual.SceneMouseNavigation.OnViewButton | ( | GenericButton | button | ) |
◆ OrthographicViewToggleOn()
| void realvirtual.SceneMouseNavigation.OrthographicViewToggleOn | ( | ) |
◆ SetNewCameraPosition()
| void realvirtual.SceneMouseNavigation.SetNewCameraPosition | ( | Vector3 | targetpos, |
| float | camdistance, | ||
| Vector3 | camrotation, | ||
| bool | nointerpolate = false |
◆ SetOrthographicView()
| void realvirtual.SceneMouseNavigation.SetOrthographicView | ( | bool | active | ) |
no changes
◆ SetViewDirection()
| void realvirtual.SceneMouseNavigation.SetViewDirection | ( | Vector3 | camrotation | ) |
◆ StartFollowing()
| void realvirtual.SceneMouseNavigation.StartFollowing | ( | GameObject | objectToFollow, |
| Vector3? | viewAngle = null, |
| bool | allowRotation = false, |
| bool | allowZoom = false, |
| float | lerpSpeed = 1::0f, |
| bool | smoothStart = true, |
| bool | stopOnMouseClick = false |
The object will remain centered in the camera view and the camera will track its movement. Following can only be stopped by calling StopFollowing() - user input cannot interrupt it.
Parameters:
- objectToFollow: The GameObject to continuously track (required)
- distance: Camera distance from object in meters. If null, auto-calculates to fit object at 1/3 screen space
- viewAngle: Initial camera rotation in degrees. If null, maintains current camera angle
- allowRotation: If true, user can orbit camera around the object while keeping it centered
- allowZoom: If true, user can zoom in/out from the object while keeping it centered
- lerpSpeed: Controls camera tracking smoothness (0.1 = very smooth, 1.0 = tight tracking, 10.0 = near instant)
- smoothStart: If true, camera smoothly lerps to target when starting. If false, jumps immediately
- stopOnMouseClick: If true, following stops when any mouse button is clicked
Example usage:
- StartFollowing(agvRobot) - Fully locked cinematic follow with default lerp
- StartFollowing(robot, allowRotation: true) - Follow with user rotation control
- StartFollowing(conveyor, lerpSpeed: 0.3f) - Smooth cinematic following
- StartFollowing(fastMover, lerpSpeed: 5.0f) - Very tight tracking for fast objects
- StartFollowing(sensor, distance: 2.5f, viewAngle: new Vector3(45, 90, 0), lerpSpeed: 2.0f) - Custom everything
- StartFollowing(target, smoothStart: false) - Jump immediately to target without initial lerp
- StartFollowing(target, stopOnMouseClick: true) - Stop following when user clicks
◆ StartFollowingObjects()
| void realvirtual.SceneMouseNavigation.StartFollowingObjects | ( | List< GameObject > | objectsToFollow, |
| float | paddingFactor = 1::2f, |
The camera tracks the combined bounds center and keeps all objects in view.
Parameters:
- objectsToFollow: List of GameObjects to track (required, must not be empty)
- paddingFactor: Extra padding around combined bounds (default 1.2 = 20% padding)
- allowRotation: If true, user can orbit camera around the group while keeping it centered
- allowZoom: If true, user can zoom in/out while keeping the group centered
◆ StartRidingTransform()
| void realvirtual.SceneMouseNavigation.StartRidingTransform | ( | GameObject | objectToRide, |
| float | lerpSpeed = 5::0f, |
Unlike StartFollowing which orbits around an object, this mode makes the camera move and rotate exactly as the followed object does. Useful for camera fly-throughs and animated sequences.
Parameters:
- objectToRide: The GameObject whose transform the camera will match
- lerpSpeed: How quickly camera follows (0.1=smooth cinematic, 5.0=tight tracking, 10.0=near instant)
- smoothStart: If true, smoothly transitions to object; if false, jumps immediately
- stopOnMouseClick: If true, stops riding when any mouse button is clicked
◆ StartStopCameraInterpolation()
| delegate void realvirtual.SceneMouseNavigation.StartStopCameraInterpolation | ( | bool | start | ) |
◆ StartStopPanning()
| delegate void realvirtual.SceneMouseNavigation.StartStopPanning | ( | bool | start | ) |
◆ StartStopRotation()
| delegate void realvirtual.SceneMouseNavigation.StartStopRotation | ( | bool | start | ) |
◆ StopFollowing()
| void realvirtual.SceneMouseNavigation.StopFollowing | ( | ) |
After calling this, the camera will return to normal user-controlled navigation.
◆ CameraInterpolationSpeed
| float realvirtual.SceneMouseNavigation.CameraInterpolationSpeed |
◆ currentDistance
| float realvirtual.SceneMouseNavigation.currentDistance |
◆ currentRotation
| Quaternion realvirtual.SceneMouseNavigation.currentRotation |
Desired distance.
◆ CursorSpeed
| float realvirtual.SceneMouseNavigation.CursorSpeed |
◆ desiredDistance
| float realvirtual.SceneMouseNavigation.desiredDistance |
Current distance.
◆ desiredRotation
| Quaternion realvirtual.SceneMouseNavigation.desiredRotation |
Current rotation.
◆ distance
| float realvirtual.SceneMouseNavigation.distance |
◆ DPIScale
| float realvirtual.SceneMouseNavigation.DPIScale |
◆ DurationNoMouseActivity
| float realvirtual.SceneMouseNavigation.DurationNoMouseActivity |
◆ EnableSpaceNavigator
| bool realvirtual.SceneMouseNavigation.EnableSpaceNavigator |
◆ FirstPersonController
| FirstPersonController realvirtual.SceneMouseNavigation.FirstPersonController |
◆ FirstPersonControllerActive
| bool realvirtual.SceneMouseNavigation.FirstPersonControllerActive |
◆ InterpolateToNewCamerapoitions
| bool realvirtual.SceneMouseNavigation.InterpolateToNewCamerapoitions |
◆ isRotating
| bool realvirtual.SceneMouseNavigation.isRotating |
Desired rotation.
◆ LastCameraPosition
| CameraPos realvirtual.SceneMouseNavigation.LastCameraPosition |
◆ MasterSensitivity
| float realvirtual.SceneMouseNavigation.MasterSensitivity |
◆ MaxHorizontalRotation
| float realvirtual.SceneMouseNavigation.MaxHorizontalRotation |
◆ minDistance
| float realvirtual.SceneMouseNavigation.minDistance |
◆ MinHorizontalRotation
| float realvirtual.SceneMouseNavigation.MinHorizontalRotation |
◆ MouseRotationSpeed
| float realvirtual.SceneMouseNavigation.MouseRotationSpeed |
◆ orthoPanSpeed
| float realvirtual.SceneMouseNavigation.orthoPanSpeed |
◆ PanDamping
| float realvirtual.SceneMouseNavigation.PanDamping |
◆ RotateToFocusObject
| bool realvirtual.SceneMouseNavigation.RotateToFocusObject |
◆ RotateWithLeftMouseButton
| bool realvirtual.SceneMouseNavigation.RotateWithLeftMouseButton |
◆ RotDamping
| float realvirtual.SceneMouseNavigation.RotDamping |
◆ SaveCameraPosOnQuit
| bool realvirtual.SceneMouseNavigation.SaveCameraPosOnQuit |
◆ SetCameraPosOnStartPlay
| bool realvirtual.SceneMouseNavigation.SetCameraPosOnStartPlay |
◆ SetEditorCameraPos
| bool realvirtual.SceneMouseNavigation.SetEditorCameraPos |
◆ SpaceNavTransSpeed
| float realvirtual.SceneMouseNavigation.SpaceNavTransSpeed |
◆ StartDemoOnInactivity
| float realvirtual.SceneMouseNavigation.StartDemoOnInactivity |
◆ target
| Transform realvirtual.SceneMouseNavigation.target |
◆ targetOffset
| Vector3 realvirtual.SceneMouseNavigation.targetOffset |
◆ Touch
| TouchInteraction realvirtual.SceneMouseNavigation.Touch |
◆ TouchInvertHorizontal
| bool realvirtual.SceneMouseNavigation.TouchInvertHorizontal |
◆ TouchPanSpeed
| float realvirtual.SceneMouseNavigation.TouchPanSpeed |
◆ TouchRotationSpeed
| float realvirtual.SceneMouseNavigation.TouchRotationSpeed |
◆ TouchZoomSpeed
| float realvirtual.SceneMouseNavigation.TouchZoomSpeed |
◆ UseOrbitCameraMode
| bool realvirtual.SceneMouseNavigation.UseOrbitCameraMode |
◆ ZoomDamping
| float realvirtual.SceneMouseNavigation.ZoomDamping |
◆ ZoomSpeed
| float realvirtual.SceneMouseNavigation.ZoomSpeed |
Property Documentation
◆ FollowedObject
get |
◆ IsFollowing
get |
◆ IsRiding
get |
