PathTracer visualizes object movement paths with optional speed-based coloring during play mode. More...
| void | ClearTrail () |
| Clears all trail points and segments immediately. | |
| void | ResetColors () |
| Resets trail colors to default cyan-to-blue gradient and disables speed-based coloring. | |
| void | SetupSpeedColoring () |
| Enables speed-based coloring with default yellow-to-pink color mapping from 0 to 2000 mm/s. | |
| bool | EnableTrail |
| Enables or disables the trail visualization. | |
| float | TrailTime |
| Duration in seconds that trail points remain visible. | |
| float | StartWidth |
| Width of the trail at the current position in millimeters. | |
| float | EndWidth |
| Width of the trail at the oldest position in millimeters. | |
| Material | TrailMaterial |
| Material applied to the trail renderer. | |
| bool | SpeedBasedColoring |
| If set to true, trail color represents movement speed. | |
| Color | SlowColor |
| Color used when object moves at minimum speed. | |
| Color | FastColor |
| Color used when object moves at maximum speed. | |
| float | MinSpeed |
| Minimum speed in millimeters per second for color mapping. | |
| float | MaxSpeed |
| Maximum speed in millimeters per second for color mapping. | |
| Gradient | TrailGradient |
| Gradient defining trail colors from newest to oldest points. | |
| float | MinimumVertexDistance |
| Minimum distance in millimeters before adding new trail point. | |
| bool | PlayModeOnly |
| If set to true, trail is only visible in play mode. | |
| LineRenderer | Trail |
| Reference to the LineRenderer component used for trail rendering. | |
| float | CurrentSpeed |
| Current movement speed in millimeters per second. | |
It creates a trail behind moving objects to help visualize motion patterns and speeds. Supports both gradient-based and speed-based coloring for visual analysis.
◆ ClearTrail()
| void realvirtual.PathTracer.ClearTrail | ( | ) |
◆ ResetColors()
| void realvirtual.PathTracer.ResetColors | ( | ) |
◆ SetupSpeedColoring()
| void realvirtual.PathTracer.SetupSpeedColoring | ( | ) |
◆ CurrentSpeed
| float realvirtual.PathTracer.CurrentSpeed |
◆ EnableTrail
| bool realvirtual.PathTracer.EnableTrail |
◆ EndWidth
| float realvirtual.PathTracer.EndWidth |
◆ FastColor
| Color realvirtual.PathTracer.FastColor |
◆ MaxSpeed
| float realvirtual.PathTracer.MaxSpeed |
◆ MinimumVertexDistance
| float realvirtual.PathTracer.MinimumVertexDistance |
◆ MinSpeed
| float realvirtual.PathTracer.MinSpeed |
◆ PlayModeOnly
| bool realvirtual.PathTracer.PlayModeOnly |
◆ SlowColor
| Color realvirtual.PathTracer.SlowColor |
◆ SpeedBasedColoring
| bool realvirtual.PathTracer.SpeedBasedColoring |
◆ StartWidth
| float realvirtual.PathTracer.StartWidth |
◆ Trail
| LineRenderer realvirtual.PathTracer.Trail |
◆ TrailGradient
| Gradient realvirtual.PathTracer.TrailGradient |
◆ TrailMaterial
| Material realvirtual.PathTracer.TrailMaterial |
◆ TrailTime
| float realvirtual.PathTracer.TrailTime |
