realvirtual.LayoutObject Class Reference
Marker component for objects placed by the Layout Planner in the WebViewer. More...
Inheritance diagram for realvirtual.LayoutObject:
| string | Label |
| Display name of the layout object. | |
| string | CatalogId |
| Reference to the library catalog entry this object was placed from. | |
| bool | Locked |
| When true, the object cannot be moved or selected in the Layout Planner. | |
LayoutObject marks a GameObject as a layout-placed component. Objects with this component are treated as selectable units in the WebViewer Layout Planner — hovering highlights the entire subtree, and clicking selects it for transform manipulation.
When Locked is true, the object cannot be moved or selected in the Layout Planner. Transform and rotation are editable in the Inspector when unlocked.
◆ CatalogId
| string realvirtual.LayoutObject.CatalogId |
◆ Label
| string realvirtual.LayoutObject.Label |
◆ Locked
| bool realvirtual.LayoutObject.Locked |
Public Attributes inherited from
