GuidedMU enables MU (material unit) objects to follow guided transport surfaces using physics constraints. More...
| void | OnSourceCreated () |
| Called when this MU is no longer a source object and can start being guided by transport surfaces. | |
| float | RaycastLength |
| Maximum distance in meters to detect transport surfaces below the MU. | |
| LayerMask | RaycastLayer |
| Layer mask defining which layers contain transport surfaces. | |
| bool | DebugMode |
| Enables visual debugging gizmos showing raycast and connection points. | |
| bool | IsFixed |
| Indicates if the MU is currently fixed by a Fixer component. | |
| override void | OnStopSim () |
It automatically detects transport surfaces below the MU and creates physical joints to guide movement along conveyors, paths, and other transport systems while maintaining proper orientation and speed synchronization.
◆ OnSourceCreated()
| void realvirtual.GuidedMU.OnSourceCreated | ( | ) |
Implements realvirtual.ISourceCreated.
◆ OnStartSim()
protectedvirtual |
◆ OnStopSim()
protectedvirtual |
◆ DebugMode
| bool realvirtual.GuidedMU.DebugMode |
◆ IsFixed
| bool realvirtual.GuidedMU.IsFixed |
◆ RaycastLayer
| LayerMask realvirtual.GuidedMU.RaycastLayer |
◆ RaycastLength
| float realvirtual.GuidedMU.RaycastLength |
