GuideLine provides linear path guidance for movement systems. More...
| void | OnDrawGizmos () |
| bool | IsActive () |
| Checks if the guide component is active and enabled. | |
| Vector3 | GetClosestDirection (Vector3 position) |
| Gets the direction of the line (always returns the transform's right vector). | |
| Vector3 | GetClosestPoint (Vector3 position) |
| Calculates the closest point on the line to the given position (clamped to line segment). | |
| float | Length |
| Length of the guide line in meters. | |
| bool | ShowGizmos |
| Shows visual representation of the line in the Scene view. | |
It defines a straight line path that objects can follow, extending from the transform position along the local right axis. Implements the IGuide interface to provide closest point and direction calculations for path following.
◆ GetClosestDirection()
| Vector3 realvirtual.GuideLine.GetClosestDirection | ( | Vector3 | position | ) |
Implements realvirtual.IGuide.
◆ GetClosestPoint()
| Vector3 realvirtual.GuideLine.GetClosestPoint | ( | Vector3 | position | ) |
◆ IsActive()
| bool realvirtual.GuideLine.IsActive | ( | ) |
◆ Length
| float realvirtual.GuideLine.Length |
◆ ShowGizmos
| bool realvirtual.GuideLine.ShowGizmos |
