| CloseConnection() | realvirtual.PerformanceTestInterface | protectedvirtual |
| CommunicationLoop(CancellationToken cancellationToken) | realvirtual.PerformanceTestInterface | protectedvirtual |
| CopyPropertiesToThreadSafe() | realvirtual.FastInterfaceBase | protectedvirtual |
| EstablishConnection(CancellationToken cancellationToken) | realvirtual.FastInterfaceBase | protectedvirtual |
| OnCommunicationStarted() | realvirtual.PerformanceTestInterface | protectedvirtual |
| RunPerformanceTests (defined in realvirtual.PerformanceTestInterface) | realvirtual.PerformanceTestInterface | |
| ShowDetailedResults (defined in realvirtual.PerformanceTestInterface) | realvirtual.PerformanceTestInterface | |
| TestIterations (defined in realvirtual.PerformanceTestInterface) | realvirtual.PerformanceTestInterface | |
