| _endarrow (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | protected |
| _startarrow (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | protected |
| AttachCurve() (defined in realvirtual.Line) | realvirtual.Line | |
| AttachLine() (defined in realvirtual.Line) | realvirtual.Line | |
| AttachPathCurve(string path, GameObject attachto) (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | |
| AttachPathLine(string path, GameObject attachto) (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | |
| AttachTo(SimulationPath path) (defined in realvirtual.Line) | realvirtual.Line | virtual |
| AttachTo(SnapPoint attachto) (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | |
| BaseReset() (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | protected |
| blockdraw (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | protected |
| ButtonInit() (defined in realvirtual.Line) | realvirtual.Line | |
| ChangeDirection(Vector3 direction) (defined in realvirtual.Line) | realvirtual.Line | |
| CheckSnap() (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | |
| CheckSnapping() (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | |
| ClearConnections() (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | |
| Connect(SnapPoint ownSnapPoint, SnapPoint snapPointMate, ISnapable mateObject, bool ismoved) (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | |
| Direction (defined in realvirtual.Line) | realvirtual.Line | |
| DirectionArrow | realvirtual.Line | |
| Disconnect(SnapPoint snapPoint, SnapPoint snapPointMate, ISnapable Mateobj, bool ismoved) (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | |
| DrawArrows() (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | protected |
| DrawPath() (defined in realvirtual.Line) | realvirtual.Line | virtual |
| Drive | realvirtual.SimulationPath | |
| DriveNotNull (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | |
| EnableSnap (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | |
| EndPoint (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | |
| EndPos (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | |
| GetAbsDirection(float abspositon) | realvirtual.BasePath | |
| GetAbsPosition(float abspositon, ref BasePath currentpath) | realvirtual.BasePath | |
| GetDirection(float normalizedposition) (defined in realvirtual.Line) | realvirtual.Line | |
| GetLength() | realvirtual.Line | |
| GetLocalDirection(float normalizedposition) | realvirtual.BasePath | |
| GetPosition(float normalizedposition, ref BasePath currentpath) (defined in realvirtual.Line) | realvirtual.Line | |
| Length | realvirtual.SimulationPath | |
| LengthChanged() (defined in realvirtual.Line) | realvirtual.Line | protectedvirtual |
| Linerenderer (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | protected |
| LocalEndPos (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | |
| LocalStartPos (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | |
| MaterialPath | realvirtual.SimulationPath | |
| Modify() (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | |
| movedlocally (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | |
| OnMyEndSnapped(SimulationPath path) (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | |
| OnMyEndUnsnapped(SimulationPath path) (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | |
| OnMyStartSnapped(SimulationPath path) (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | |
| OnMyStartUnsnapped(SimulationPath path) (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | |
| OnPathEnd | realvirtual.SimulationPath | |
| OnPathEntered | realvirtual.SimulationPath | |
| OnPathExit | realvirtual.SimulationPath | |
| OnSnapped (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | |
| PathStrategy | realvirtual.SimulationPath | |
| Predecessors | realvirtual.SimulationPath | |
| Reset() (defined in realvirtual.Line) | realvirtual.Line | |
| setStart() (defined in realvirtual.Line) | realvirtual.Line | |
| SetStartTo0() (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | protected |
| ShowPathOnSimulation | realvirtual.SimulationPath | |
| SizeDirectionArrow | realvirtual.SimulationPath | |
| StartPoint (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | |
| Successors | realvirtual.SimulationPath | |
| Thickness | realvirtual.SimulationPath | |
| transformposchanged (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | |
| TransportableEntered(PathMover trans) (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | |
| TransportableExit(PathMover trans) (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | |
| TransportableOnEnd(PathMover trans) (defined in realvirtual.SimulationPath) | realvirtual.SimulationPath | |
