realvirtual.LODGenerator Class Reference
Contains methods for generating LODs (level of details) for game objects. More...
| static LODGroup | GenerateLODs (LODGeneratorHelper generatorHelper) |
| Generates the LODs and sets up a LOD Group for the LOD generator helper component. | |
| static LODGroup | GenerateLODs (GameObject gameObject, LODLevel[] levels, bool autoCollectRenderers, SimplificationOptions simplificationOptions) |
| Generates the LODs and sets up a LOD Group for the specified game object. | |
| static LODGroup | GenerateLODs (GameObject gameObject, LODLevel[] levels, bool autoCollectRenderers, SimplificationOptions simplificationOptions, string saveAssetsPath) |
| static bool | DestroyLODs (LODGeneratorHelper generatorHelper) |
| Destroys the generated LODs and LOD Group for the specified game object. | |
| static bool | DestroyLODs (GameObject gameObject) |
Static Public Attributes | |
| const string | LODParentGameObjectName |
| The name of the game object where generated LODs are parented under. | |
| const string | LODAssetParentPath |
| The parent path for generated LOD assets. | |
◆ DestroyLODs() [1/2]
static |
- Parameters
gameObject The game object to destroy LODs for.
- Returns
- If the LODs were successfully destroyed.
◆ DestroyLODs() [2/2]
static |
- Parameters
generatorHelper The LOD generator helper.
- Returns
◆ GenerateLODs() [1/3]
static |
- Parameters
gameObject The game object to set up. levels The LOD levels to set up. autoCollectRenderers If the renderers under the game object and any children should be automatically collected. Enabling this will ignore any renderers defined under each LOD level. simplificationOptions The mesh simplification options.
- Returns
- The generated LOD Group.
◆ GenerateLODs() [2/3]
static |
- Parameters
gameObject The game object to set up. levels The LOD levels to set up. autoCollectRenderers If the renderers under the game object and any children should be automatically collected. Enabling this will ignore any renderers defined under each LOD level. simplificationOptions The mesh simplification options. saveAssetsPath The path to where the generated assets should be saved. Can be null or empty to use the default path.
- Returns
◆ GenerateLODs() [3/3]
static |
- Parameters
- Returns
◆ LODAssetParentPath
static |
◆ LODParentGameObjectName
static |
