A LOD (level of detail) level. More...
| LODLevel (float screenRelativeTransitionHeight, float quality) | |
| Creates a new LOD level. | |
| LODLevel (float screenRelativeTransitionHeight, float fadeTransitionWidth, float quality, bool combineMeshes, bool combineSubMeshes) | |
| LODLevel (float screenRelativeTransitionHeight, float fadeTransitionWidth, float quality, bool combineMeshes, bool combineSubMeshes, Renderer[] renderers) | |
Properties | |
| float | ScreenRelativeTransitionHeight [get, set] |
| Gets or sets the screen relative height to use for the transition [0-1]. | |
| float | FadeTransitionWidth [get, set] |
| Gets or sets the width of the cross-fade transition zone (proportion to the current LOD's whole length) [0-1]. | |
| float | Quality [get, set] |
| Gets or sets the quality of this level [0-1]. | |
| bool | CombineMeshes [get, set] |
| Gets or sets if all renderers and meshes under this level should be combined into one, where possible. | |
| bool | CombineSubMeshes [get, set] |
| Gets or sets if all sub-meshes should be combined into one, where possible. | |
| Renderer[] | Renderers [get, set] |
| Gets or sets the renderers used in this level. | |
| SkinQuality | SkinQuality [get, set] |
| Gets or sets the skin quality to use for renderers on this level. | |
| ShadowCastingMode | ShadowCastingMode [get, set] |
| Gets or sets the shadow casting mode for renderers on this level. | |
| bool | ReceiveShadows [get, set] |
| Gets or sets if renderers on this level should receive shadows. | |
| MotionVectorGenerationMode | MotionVectorGenerationMode [get, set] |
| Gets or sets the motion vector generation mode for renderers on this level. | |
| bool | SkinnedMotionVectors [get, set] |
| Gets or sets if renderers on this level should use skinned motion vectors. | |
| LightProbeUsage | LightProbeUsage [get, set] |
| Gets or sets the light probe usage for renderers on this level. | |
| ReflectionProbeUsage | ReflectionProbeUsage [get, set] |
| Gets or sets the reflection probe usage for renderers on this level. | |
Constructor & Destructor Documentation
◆ LODLevel() [1/3]
| realvirtual.LODLevel.LODLevel | ( | float | screenRelativeTransitionHeight, |
| float | quality | ||
- Parameters
screenRelativeTransitionHeight The screen relative height to use for the transition [0-1]. quality The quality of this level [0-1].
◆ LODLevel() [2/3]
| float | fadeTransitionWidth, | ||
| float | quality, | ||
| bool | combineMeshes, | ||
| bool | combineSubMeshes | ||
- Parameters
screenRelativeTransitionHeight The screen relative height to use for the transition [0-1]. fadeTransitionWidth The width of the cross-fade transition zone (proportion to the current LOD's whole length) [0-1]. Only used if it's not animated. quality The quality of this level [0-1]. combineMeshes If all renderers and meshes under this level should be combined into one, where possible. combineSubMeshes If all sub-meshes should be combined into one, where possible.
◆ LODLevel() [3/3]
| bool | combineSubMeshes, | ||
| Renderer[] | renderers | ||
- Parameters
screenRelativeTransitionHeight The screen relative height to use for the transition [0-1]. fadeTransitionWidth The width of the cross-fade transition zone (proportion to the current LOD's whole length) [0-1]. Only used if it's not animated. quality The quality of this level [0-1]. combineMeshes If all renderers and meshes under this level should be combined into one, where possible. combineSubMeshes If all sub-meshes should be combined into one, where possible. renderers The renderers used in this level.
Property Documentation
◆ CombineMeshes
getset |
◆ CombineSubMeshes
getset |
NOTE: This is only used if CombineMeshes is true.
◆ FadeTransitionWidth
getset |
◆ LightProbeUsage
getset |
◆ MotionVectorGenerationMode
getset |
◆ Quality
getset |
◆ ReceiveShadows
getset |
◆ ReflectionProbeUsage
getset |
◆ Renderers
getset |
These will have no purpose if automatic collection is used for the LOD generator.
◆ ScreenRelativeTransitionHeight
getset |
◆ ShadowCastingMode
getset |
◆ SkinnedMotionVectors
getset |
◆ SkinQuality
getset |
