| CloseInterface() (defined in realvirtual.InterfaceBaseClass) | realvirtual.InterfaceBaseClass | virtual |
| MotionGroup | realvirtual.WandelbotsNOVAInterface | |
| OnEditModeFinished() (defined in realvirtual.WandelbotsNOVAInterface) | realvirtual.WandelbotsNOVAInterface | |
| OpenInterface() (defined in realvirtual.InterfaceBaseClass) | realvirtual.InterfaceBaseClass | virtual |
| PostAllScenesLoaded() (defined in realvirtual.InterfaceBaseClass) | realvirtual.InterfaceBaseClass | |
| SetCollider(bool enabled) | realvirtual.realvirtualBehavior | |
| WandelbotsServer | realvirtual.WandelbotsNOVAInterface | |
