Extension methods for SnapPoint to simplify querying connected components. More...
| static IEnumerable< T > | GetConnectedComponents< T > (this SnapPoint snapPoint) |
| Gets all connected components of the specified type from a snap point. | |
| static T | GetFirstConnected< T > (this SnapPoint snapPoint) |
| Gets the first connected component of the specified type, or null if none found. | |
| static bool | HasConnections (this SnapPoint snapPoint) |
| Checks if the snap point has any connections (mate or mates). | |
| static bool | AnyConnected< T > (this SnapPoint snapPoint, System.Func< T, bool > predicate) |
| Checks if any connected component of type T satisfies a condition. | |
These extension methods provide a fluent, LINQ-friendly API for working with snap point connections. They handle both single mate and multiple mates scenarios transparently, making it easy to query connected components.
Key Features:
- Query connected components by type with GetConnectedComponents<T>()
- Check for any connections with HasConnections()
- Get first connected component with GetFirstConnected<T>()
- LINQ-compatible IEnumerable results
- Null-safe implementations
Usage Example: // Check if any connected conveyor is occupied bool anyOccupied = snapOut.GetConnectedComponents<IPalletHandling>() .Any(h => h.GetOccupied());
// Get all connected conveyors var conveyors = snapOut.GetConnectedComponents<PalletConveyor>().ToList();
// Quick connection check if (snapIn.HasConnections()) { // Has predecessors }
◆ AnyConnected< T >()
static |
Convenience method combining GetConnectedComponents with a predicate check. More efficient than ToList().Any() since it uses deferred execution.
- Template Parameters
T The component type to search for
- Parameters
snapPoint The snap point to query for connections predicate The condition to test each connected component against
- Returns
- True if any connected component of type T satisfies the predicate
Example:
- Type Constraints
T : class
◆ GetConnectedComponents< T >()
static |
This method traverses both single mate and multiple mates connections, searching for components of type T in the parent hierarchy of each connected snap point. Returns an IEnumerable for LINQ compatibility.
T The component type to search for (e.g., IPalletHandling, Drive, Sensor)
- Parameters
- Returns
- An enumerable of all connected components of type T (may be empty)
Example:
- Type Constraints
T : class
◆ GetFirstConnected< T >()
static |
Convenience method for when you only need the first connected component or know there should only be one connection.
- Parameters
- Returns
- The first connected component of type T, or null if none found
Example:
- Type Constraints
T : class
◆ HasConnections()
static |
Quick boolean check for whether a snap point is connected to anything. More efficient than checking GetConnectedComponents().Any() since it doesn't need to traverse the component hierarchy.
- Parameters
snapPoint The snap point to check
- Returns
- True if the snap point has at least one connection, false otherwise
Example:
