Records and traces signal values over time for analysis and debugging purposes. More...
| void | InitValue (string valuename) |
| Initializes a trace for a named value. Must be called before tracing the value. | |
| void | TraceValue (string valuename, float value) |
| Records a value at the current time in the signal trace. | |
| void | TraceValue (string valuename, float time, float value) |
| Records a value at a specific time in the signal trace. | |
| void | CopyTracesToReference (string reference) |
| Saves the current traces as a reference for later comparison. | |
| float | CompareCurves (string curve1, string curve2, float tolerance) |
| Compares two signal curves and returns the difference. | |
| void | StartTrace () |
| Starts recording signal values for all signals in the TracedSignals list. | |
| List< Signal > | TracedSignals |
| List of signals to trace and record. | |
| SignalTrace | SignalTrace |
| ScriptableObject asset for storing the recorded trace data. | |
| bool | TraceAtStart |
| If true, automatically starts tracing when the component starts. | |
Supports tracing of bool, int, and float signals with automatic value recording at each fixed update. Traces can be saved as references and compared for testing or optimization purposes.
◆ CompareCurves()
| float realvirtual.SignalTracer.CompareCurves | ( | string | curve1, |
| string | curve2, | ||
| float | tolerance | ||
◆ CopyTracesToReference()
| void realvirtual.SignalTracer.CopyTracesToReference | ( | string | reference | ) |
◆ InitValue()
| void realvirtual.SignalTracer.InitValue | ( | string | valuename | ) |
◆ StartTrace()
| void realvirtual.SignalTracer.StartTrace | ( | ) |
◆ TraceValue() [1/2]
| void realvirtual.SignalTracer.TraceValue | ( | string | valuename, |
| float | time, | ||
| float | value | ||
◆ TraceValue() [2/2]
| float | value | ||
◆ SignalTrace
| SignalTrace realvirtual.SignalTracer.SignalTrace |
◆ TraceAtStart
| bool realvirtual.SignalTracer.TraceAtStart |
◆ TracedSignals
| List<Signal> realvirtual.SignalTracer.TracedSignals |
