| Awake() (defined in realvirtual.RealvirtualTooltip) | realvirtual.RealvirtualTooltip | protected |
| getHeight() (defined in realvirtual.RealvirtualTooltip) | realvirtual.RealvirtualTooltip | |
| GetHeight() (defined in realvirtual.RealvirtualTooltip) | realvirtual.RealvirtualTooltip | |
| GetWidth() (defined in realvirtual.RealvirtualTooltip) | realvirtual.RealvirtualTooltip | |
| Placement enum name (defined in realvirtual.RealvirtualTooltip) | realvirtual.RealvirtualTooltip | |
| PositionRelativeTo(RectTransform targetRect, Placement preferredPlacement=Placement.Auto, float margin=DefaultMargin) | realvirtual.RealvirtualTooltip | |
| PositionRelativeTo(Vector3[] targetCorners, UI.Tooltipposition position, float margin=DefaultMargin) | realvirtual.RealvirtualTooltip | |
| SetPosition(Vector3 pos) (defined in realvirtual.RealvirtualTooltip) | realvirtual.RealvirtualTooltip | |
| SetTooltip(string tip) (defined in realvirtual.RealvirtualTooltip) | realvirtual.RealvirtualTooltip | |
| UpdateUISkinParameter(RealvirtualUISkin skin) (defined in realvirtual.IUISkinEdit) | realvirtual.IUISkinEdit | |
