| CalculateLength() (defined in realvirtual.PathChain) | realvirtual.PathChain | |
| GetClosestDirection(Vector3 position) (defined in realvirtual.PathChain) | realvirtual.PathChain | |
| GetClosestPoint(Vector3 position) (defined in realvirtual.PathChain) | realvirtual.PathChain | |
| GetDirection(float normalizedposition, bool normalized=true) (defined in realvirtual.PathChain) | realvirtual.PathChain | |
| GetPosition(float normalizedposition, bool normalized=true) (defined in realvirtual.PathChain) | realvirtual.PathChain | |
| GetUpDirection(float normalizedposition, bool normalized=true) (defined in realvirtual.PathChain) | realvirtual.PathChain | |
| Length (defined in realvirtual.PathChain) | realvirtual.PathChain | |
| PathForChain (defined in realvirtual.PathChain) | realvirtual.PathChain | |
| Startelement (defined in realvirtual.PathChain) | realvirtual.PathChain | |
| UseSimulationPath() (defined in realvirtual.PathChain) | realvirtual.PathChain | |
