Generic attribute to mark custom overlay buttons for automatic discovery and registration.
More...
| Type | OverlayType [get, set] |
| | Type of overlay this button should appear in (e.g., typeof(QuickEditOverlay))
| double | Order [get, set] |
| | Display order of the button (decimal: integer=row, fractional=position in row) Lower values appear first.
| string | Section [get, set] |
| | Section name for organizing buttons (e.g., "Transform", "Components", "Custom") Each overlay defines its own sections.
| bool | FullWidth [get, set] |
| | Whether this button should take full width of the overlay.
| Type | TargetComponentType [get, set] |
| | Type of component required for this button to be visible (optional) Example: typeof(Drive) - button only shows when Drive component is selected.
| bool | RequiresSelection [get, set] |
| | Whether this button requires an active selection in the scene.
| bool | PlayModeOnly [get, set] |
| | Whether this button is only available in play mode.
| bool | EditModeOnly [get, set] |
| | Whether this button is only available in edit mode.
| bool | EnabledByDefault [get, set] |
| | Whether this button is enabled by default.
| string | Group [get, set] |
| | Optional group name for further organizing buttons within a section.
This attribute can be applied multiple times to register the same button in different overlays.
The decimal order system allows precise control over button placement:
- Integer part (e.g., 100) defines the row
- Decimal part (e.g., 0.1, 0.2) defines position within the row (left to right)
Example usage:
[OverlayButton(typeof(QuickEditOverlay), order: 100.0, section: "Custom")]
[OverlayButton(typeof(QuickEditOverlay), order: 100.0, section: "Components")]
[OverlayButton(typeof(DesOverlay), order: 50.0, section: "Tools")]
[OverlayButton(typeof(QuickEditOverlay), order: 100.1, section: "Custom")]
[OverlayButton(typeof(QuickEditOverlay), order: 100.2, section: "Custom")]
[OverlayButton(typeof(QuickEditOverlay), order: 101.0, section: "Custom")]
