The mesh simplifier. More...
| MeshSimplifier () | |
| Creates a new mesh simplifier. | |
| MeshSimplifier (Mesh mesh) | |
| int[][] | GetAllSubMeshTriangles () |
| Returns the triangle indices for all sub-meshes. | |
| int[] | GetSubMeshTriangles (int subMeshIndex) |
| Returns the triangle indices for a specific sub-mesh. | |
| void | ClearSubMeshes () |
| Clears out all sub-meshes. | |
| void | AddSubMeshTriangles (int[] triangles) |
| Adds a sub-mesh triangle indices for a specific sub-mesh. | |
| void | AddSubMeshTriangles (int[][] triangles) |
| Adds several sub-meshes at once with their triangle indices for each sub-mesh. | |
| Vector2[] | GetUVs2D (int channel) |
| Returns the UVs (2D) from a specific channel. | |
| Vector3[] | GetUVs3D (int channel) |
| Returns the UVs (3D) from a specific channel. | |
| Vector4[] | GetUVs4D (int channel) |
| Returns the UVs (4D) from a specific channel. | |
| void | GetUVs (int channel, List< Vector2 > uvs) |
| void | GetUVs (int channel, List< Vector3 > uvs) |
| void | GetUVs (int channel, List< Vector4 > uvs) |
| void | SetUVs (int channel, Vector2[] uvs) |
| Sets the UVs (2D) for a specific channel. | |
| void | SetUVs (int channel, Vector3[] uvs) |
| Sets the UVs (3D) for a specific channel. | |
| void | SetUVs (int channel, Vector4[] uvs) |
| Sets the UVs (4D) for a specific channel. | |
| void | SetUVs (int channel, List< Vector2 > uvs) |
| void | SetUVs (int channel, List< Vector3 > uvs) |
| void | SetUVs (int channel, List< Vector4 > uvs) |
| void | SetUVsAuto (int channel, List< Vector4 > uvs) |
| Sets the UVs for a specific channel and automatically detects the used components. | |
| BlendShape[] | GetAllBlendShapes () |
| Returns all blend shapes. | |
| BlendShape | GetBlendShape (int blendShapeIndex) |
| Returns a specific blend shape. | |
| void | ClearBlendShapes () |
| Clears all blend shapes. | |
| void | AddBlendShape (BlendShape blendShape) |
| Adds a blend shape. | |
| void | AddBlendShapes (BlendShape[] blendShapes) |
| Adds several blend shapes. | |
| void | Initialize (Mesh mesh) |
| Initializes the algorithm with the original mesh. | |
| void | SimplifyMesh (float quality) |
| Simplifies the mesh to a desired quality. | |
| void | SimplifyMeshLossless () |
| Simplifies the mesh without losing too much quality. | |
| Mesh | ToMesh () |
| Returns the resulting mesh. | |
Properties | |
| bool | PreserveBorders [get, set] |
| Gets or sets if the border edges should be preserved. | |
| bool | PreserveBorderEdges [get, set] |
| bool | PreserveSeams [get, set] |
| Gets or sets if the UV seam edges should be preserved. | |
| bool | PreserveUVSeamEdges [get, set] |
| bool | PreserveFoldovers [get, set] |
| Gets or sets if the UV foldover edges should be preserved. | |
| bool | PreserveUVFoldoverEdges [get, set] |
| bool | EnableSmartLink [get, set] |
| Gets or sets if a feature for smarter vertex linking should be enabled, reducing artifacts in the decimated result at the cost of a slightly more expensive initialization by treating vertices at the same position as the same vertex while separating the attributes. | |
| int | MaxIterationCount [get, set] |
| Gets or sets the maximum iteration count. | |
| double | Agressiveness [get, set] |
| Gets or sets the agressiveness of the mesh simplification. | |
| bool | Verbose [get, set] |
| Gets or sets if verbose information should be printed to the console. | |
| double | VertexLinkDistance [get, set] |
| Gets or sets the maximum distance between two vertices in order to link them. | |
| double | VertexLinkDistanceSqr [get, set] |
| Gets or sets the maximum squared distance between two vertices in order to link them. | |
| Vector3[] | Vertices [get, set] |
| Gets or sets the vertex positions. | |
| int | SubMeshCount [get] |
| Gets the count of sub-meshes. | |
| int | BlendShapeCount [get] |
| Gets the count of blend shapes. | |
| Vector3[] | Normals [get, set] |
| Gets or sets the vertex normals. | |
| Vector4[] | Tangents [get, set] |
| Gets or sets the vertex tangents. | |
| Vector2[] | UV1 [get, set] |
| Gets or sets the vertex 2D UV set 1. | |
| Vector2[] | UV2 [get, set] |
| Gets or sets the vertex 2D UV set 2. | |
| Vector2[] | UV3 [get, set] |
| Gets or sets the vertex 2D UV set 3. | |
| Vector2[] | UV4 [get, set] |
| Gets or sets the vertex 2D UV set 4. | |
| Color[] | Colors [get, set] |
| Gets or sets the vertex colors. | |
| BoneWeight[] | BoneWeights [get, set] |
| Gets or sets the vertex bone weights. | |
Deeply based on https://github.com/sp4cerat/Fast-Quadric-Mesh-Simplification but rewritten completely in C#.
Constructor & Destructor Documentation
◆ MeshSimplifier() [1/2]
| realvirtual.MeshSimplifier.MeshSimplifier | ( | ) |
◆ MeshSimplifier() [2/2]
| realvirtual.MeshSimplifier.MeshSimplifier | ( | Mesh | mesh | ) |
- Parameters
mesh The original mesh to simplify.
◆ AddBlendShape()
| void realvirtual.MeshSimplifier.AddBlendShape | ( | BlendShape | blendShape | ) |
Adds a blend shape.
- Parameters
blendShape The blend shape to add.
◆ AddBlendShapes()
| void realvirtual.MeshSimplifier.AddBlendShapes | ( | BlendShape[] | blendShapes | ) |
- Parameters
blendShapes The blend shapes to add.
◆ AddSubMeshTriangles() [1/2]
| void realvirtual.MeshSimplifier.AddSubMeshTriangles | ( | int[] | triangles | ) |
- Parameters
triangles The triangle indices.
◆ AddSubMeshTriangles() [2/2]
| void realvirtual.MeshSimplifier.AddSubMeshTriangles | ( | int | triangles[][] | ) |
- Parameters
triangles The triangle indices for each sub-mesh.
◆ ClearBlendShapes()
| void realvirtual.MeshSimplifier.ClearBlendShapes | ( | ) |
◆ ClearSubMeshes()
| void realvirtual.MeshSimplifier.ClearSubMeshes | ( | ) |
◆ GetAllBlendShapes()
| BlendShape[] realvirtual.MeshSimplifier.GetAllBlendShapes | ( | ) |
- Returns
- An array of all blend shapes.
◆ GetAllSubMeshTriangles()
| int[][] realvirtual.MeshSimplifier.GetAllSubMeshTriangles | ( | ) |
- Returns
- The triangle indices for all sub-meshes.
◆ GetBlendShape()
| BlendShape realvirtual.MeshSimplifier.GetBlendShape | ( | int | blendShapeIndex | ) |
- Parameters
blendShapeIndex The blend shape index.
- Returns
- The blend shape.
◆ GetSubMeshTriangles()
| int[] realvirtual.MeshSimplifier.GetSubMeshTriangles | ( | int | subMeshIndex | ) |
- Parameters
subMeshIndex The sub-mesh index.
- Returns
- The triangle indices.
◆ GetUVs() [1/3]
| void realvirtual.MeshSimplifier.GetUVs | ( | int | channel, |
| List< Vector2 > | uvs | ||
- Parameters
channel The channel index. uvs The UVs.
◆ GetUVs() [2/3]
| List< Vector3 > | uvs | ||
- Parameters
◆ GetUVs() [3/3]
| List< Vector4 > | uvs | ||
- Parameters
◆ GetUVs2D()
| Vector2[] realvirtual.MeshSimplifier.GetUVs2D | ( | int | channel | ) |
- Parameters
- Returns
- The UVs.
◆ GetUVs3D()
| Vector3[] realvirtual.MeshSimplifier.GetUVs3D | ( | int | channel | ) |
- Parameters
- Returns
- The UVs.
◆ GetUVs4D()
| Vector4[] realvirtual.MeshSimplifier.GetUVs4D | ( | int | channel | ) |
- Parameters
- Returns
- The UVs.
◆ Initialize()
| void realvirtual.MeshSimplifier.Initialize | ( | Mesh | mesh | ) |
- Parameters
mesh The mesh.
◆ SetUVs() [1/6]
| void realvirtual.MeshSimplifier.SetUVs | ( | int | channel, |
- Parameters
◆ SetUVs() [2/6]
- Parameters
◆ SetUVs() [3/6]
- Parameters
◆ SetUVs() [4/6]
| Vector2[] | uvs | ||
- Parameters
◆ SetUVs() [5/6]
| Vector3[] | uvs | ||
- Parameters
◆ SetUVs() [6/6]
| Vector4[] | uvs | ||
- Parameters
◆ SetUVsAuto()
| void realvirtual.MeshSimplifier.SetUVsAuto | ( | int | channel, |
- Parameters
◆ SimplifyMesh()
| void realvirtual.MeshSimplifier.SimplifyMesh | ( | float | quality | ) |
- Parameters
quality The target quality (between 0 and 1).
◆ SimplifyMeshLossless()
| void realvirtual.MeshSimplifier.SimplifyMeshLossless | ( | ) |
◆ ToMesh()
| Mesh realvirtual.MeshSimplifier.ToMesh | ( | ) |
- Returns
- The resulting mesh.
Property Documentation
◆ Agressiveness
getset |
Higher number equals higher quality, but more expensive to run. Default value: 7.0
◆ BlendShapeCount
get |
◆ BoneWeights
getset |
◆ Colors
getset |
◆ EnableSmartLink
getset |
Default value: true
◆ MaxIterationCount
getset |
Higher number is more expensive but can bring you closer to your target quality. Sometimes a lower maximum count might be desired in order to lower the performance cost. Default value: 100
◆ Normals
getset |
◆ PreserveBorderEdges
getset |
Default value: false
◆ PreserveBorders
getset |
◆ PreserveFoldovers
getset |
◆ PreserveSeams
getset |
◆ PreserveUVFoldoverEdges
getset |
◆ PreserveUVSeamEdges
getset |
◆ SubMeshCount
get |
◆ Tangents
getset |
◆ UV1
getset |
◆ UV2
getset |
◆ UV3
getset |
◆ UV4
getset |
◆ Verbose
getset |
◆ VertexLinkDistance
getset |
Note that this value is only used if EnableSmartLink is true.
◆ VertexLinkDistanceSqr
getset |
Note that this value is only used if EnableSmartLink is true. Default value: double.Epsilon
◆ Vertices
getset |
