realvirtual.MathHelper Class Reference
Math helpers. More...
| static double | Min (double val1, double val2, double val3) |
| Returns the minimum of three values. | |
| static double | Clamp (double value, double min, double max) |
| Clamps a value between a minimum and a maximum value. | |
| static double | TriangleArea (ref Vector3d p0, ref Vector3d p1, ref Vector3d p2) |
| Calculates the area of a triangle. | |
Static Public Attributes | |
| const float | PI |
| The Pi constant. | |
| const double | PId |
| const float | Deg2Rad |
| Degrees to radian constant. | |
| const double | Deg2Radd |
| const float | Rad2Deg |
| Radians to degrees constant. | |
| const double | Rad2Degd |
Math helpers.
◆ Clamp()
static |
- Parameters
value The value to clamp. min The minimum value. max The maximum value.
- Returns
- The clamped value.
◆ Min()
static |
- Parameters
val1 The first value. val2 The second value. val3 The third value.
- Returns
- The minimum value.
◆ TriangleArea()
static |
- Parameters
p0 The first point. p1 The second point. p2 The third point.
- Returns
- The triangle area.
◆ Deg2Rad
static |
◆ Deg2Radd
static |
◆ PI
static |
The Pi constant.
◆ PId
static |
The Pi constant.
◆ Rad2Deg
static |
◆ Rad2Degd
static |
