A double precision 3D vector. More...
| Vector3d (double value) | |
| Creates a new vector with one value for all components. | |
| Vector3d (double x, double y, double z) | |
| Creates a new vector. | |
| Vector3d (Vector3 vector) | |
| Creates a new vector from a single precision vector. | |
| void | Set (double x, double y, double z) |
| Set x, y and z components of an existing vector. | |
| void | Scale (ref Vector3d scale) |
| Multiplies with another vector component-wise. | |
| void | Normalize () |
| Normalizes this vector. | |
| void | Clamp (double min, double max) |
| Clamps this vector between a specific range. | |
| override int | GetHashCode () |
| Returns a hash code for this vector. | |
| override bool | Equals (object other) |
| Returns if this vector is equal to another one. | |
| bool | Equals (Vector3d other) |
| override string | ToString () |
| Returns a nicely formatted string for this vector. | |
| string | ToString (string format) |
| static Vector3d | operator+ (Vector3d a, Vector3d b) |
| Adds two vectors. | |
| static Vector3d | operator- (Vector3d a, Vector3d b) |
| Subtracts two vectors. | |
| static Vector3d | operator* (Vector3d a, double d) |
| Scales the vector uniformly. | |
| static Vector3d | operator* (double d, Vector3d a) |
| static Vector3d | operator/ (Vector3d a, double d) |
| Divides the vector with a float. | |
| static Vector3d | operator- (Vector3d a) |
| Subtracts the vector from a zero vector. | |
| static bool | operator== (Vector3d lhs, Vector3d rhs) |
| Returns if two vectors equals eachother. | |
| static bool | operator!= (Vector3d lhs, Vector3d rhs) |
| Returns if two vectors don't equal eachother. | |
| static implicit | operator Vector3d (Vector3 v) |
| Implicitly converts from a single-precision vector into a double-precision vector. | |
| static | operator Vector3 (Vector3d v) |
| Implicitly converts from a double-precision vector into a single-precision vector. | |
| static double | Dot (ref Vector3d lhs, ref Vector3d rhs) |
| Dot Product of two vectors. | |
| static void | Cross (ref Vector3d lhs, ref Vector3d rhs, out Vector3d result) |
| Cross Product of two vectors. | |
| static double | Angle (ref Vector3d from, ref Vector3d to) |
| Calculates the angle between two vectors. | |
| static void | Lerp (ref Vector3d a, ref Vector3d b, double t, out Vector3d result) |
| Performs a linear interpolation between two vectors. | |
| static void | Scale (ref Vector3d a, ref Vector3d b, out Vector3d result) |
| Multiplies two vectors component-wise. | |
| static void | Normalize (ref Vector3d value, out Vector3d result) |
| Normalizes a vector. | |
| double | x |
| The x component. | |
| double | y |
| The y component. | |
| double | z |
| The z component. | |
Static Public Attributes | |
| static readonly Vector3d | zero |
| The zero vector. | |
| const double | Epsilon |
| The vector epsilon. | |
Properties | |
| double | Magnitude [get] |
| Gets the magnitude of this vector. | |
| double | MagnitudeSqr [get] |
| Gets the squared magnitude of this vector. | |
| Vector3d | Normalized [get] |
| Gets a normalized vector from this vector. | |
| double | this[int index] [get, set] |
| Gets or sets a specific component by index in this vector. | |
Constructor & Destructor Documentation
◆ Vector3d() [1/3]
| realvirtual.Vector3d.Vector3d | ( | double | value | ) |
- Parameters
value The value.
◆ Vector3d() [2/3]
| realvirtual.Vector3d.Vector3d | ( | double | x, |
| double | y, | ||
| double | z | ||
- Parameters
x The x value. y The y value. z The z value.
◆ Vector3d() [3/3]
| realvirtual.Vector3d.Vector3d | ( | Vector3 | vector | ) |
- Parameters
vector The single precision vector.
◆ Angle()
- Parameters
from The from vector. to The to vector.
- Returns
- The angle.
◆ Clamp()
| void realvirtual.Vector3d.Clamp | ( | double | min, |
| double | max | ||
- Parameters
min The minimum component value. max The maximum component value.
◆ Cross()
static |
- Parameters
lhs The left hand side vector. rhs The right hand side vector. result The resulting vector.
◆ Dot()
- Parameters
◆ Equals() [1/2]
| override bool realvirtual.Vector3d.Equals | ( | object | other | ) |
- Parameters
other The other vector to compare to.
- Returns
- If equals.
◆ Equals() [2/2]
| bool realvirtual.Vector3d.Equals | ( | Vector3d | other | ) |
- Parameters
- Returns
- If equals.
◆ GetHashCode()
| override int realvirtual.Vector3d.GetHashCode | ( | ) |
- Returns
- The hash code.
◆ Lerp()
static |
- Parameters
a The vector to interpolate from. b The vector to interpolate to. t The time fraction. result The resulting vector.
◆ Normalize() [1/2]
| void realvirtual.Vector3d.Normalize | ( | ) |
◆ Normalize() [2/2]
- Parameters
value The vector to normalize. result The resulting normalized vector.
◆ operator Vector3()
explicitstatic |
- Parameters
v The double-precision vector.
◆ operator Vector3d()
static |
- Parameters
v The single-precision vector.
◆ operator!=()
- Parameters
- Returns
- If not equals.
◆ operator*() [1/2]
- Parameters
d The scaling vlaue. a The vector.
- Returns
- The resulting vector.
◆ operator*() [2/2]
- Parameters
a The vector. d The scaling value.
- Returns
◆ operator+()
Adds two vectors.
- Parameters
a The first vector. b The second vector.
- Returns
◆ operator-() [1/2]
- Parameters
a The vector.
- Returns
◆ operator-() [2/2]
- Parameters
- Returns
◆ operator/()
- Parameters
a The vector. d The dividing float value.
- Returns
◆ operator==()
- Parameters
- Returns
- If equals.
◆ Scale() [1/2]
static |
- Parameters
a The first vector. b The second vector. result The resulting vector.
◆ Scale() [2/2]
| void realvirtual.Vector3d.Scale | ( | ref Vector3d | scale | ) |
- Parameters
scale The vector to multiply with.
◆ Set()
| void realvirtual.Vector3d.Set | ( | double | x, |
| double | y, | ||
| double | z | ||
- Parameters
◆ ToString() [1/2]
| override string realvirtual.Vector3d.ToString | ( | ) |
- Returns
- The string.
◆ ToString() [2/2]
| string realvirtual.Vector3d.ToString | ( | string | format | ) |
- Parameters
format The float format.
- Returns
- The string.
◆ Epsilon
static |
The vector epsilon.
◆ x
| double realvirtual.Vector3d.x |
The x component.
◆ y
| double realvirtual.Vector3d.y |
The y component.
◆ z
| double realvirtual.Vector3d.z |
The z component.
◆ zero
static |
The zero vector.
Property Documentation
◆ Magnitude
get |
◆ MagnitudeSqr
get |
◆ Normalized
get |
◆ this[int index]
getset |
- Parameters
index The component index.
