realvirtual.LogicStep_JumpOnSignal Class Reference
Logic step that conditionally jumps to another named step based on a signal value. More...
Inheritance diagram for realvirtual.LogicStep_JumpOnSignal:
| string | JumpToStep |
| Name of the logic step to jump to when condition is met. | |
| Signal | Signal |
| The signal to evaluate for the jump condition. | |
| bool | JumpOn |
| Jump when signal equals this value (true or false) | |
Public Attributes inherited from realvirtual.LogicStep | |
| Name identifier for this logic step, used for jumps and debugging. | |
| float | State |
| Current execution state as percentage (0-100) | |
| bool | StepActive |
| True when this step is currently executing. | |
| bool | IsWaiting |
| True when this step is waiting for a condition. | |
| bool | IsContainer |
| True if this step is a container for other steps. | |
| new bool | NonBlocking () |
| override void | OnStarted () |
Protected Member Functions inherited from realvirtual.LogicStep | |
| virtual void | OnStartInit () |
| void | NextStep () |
| void | NextStep (string name) |
| void | Start () |
Public Member Functions inherited from realvirtual.LogicStep | |
| void | StartStep () |
| Starts the execution of this logic step. | |
Properties inherited from realvirtual.LogicStep | |
| bool | IsShowingRuntimeInfo [get] |
This non-blocking step enables branching logic in automation sequences. If the signal matches the specified condition, execution jumps to the named step; otherwise continues normally.
◆ JumpOn
| bool realvirtual.LogicStep_JumpOnSignal.JumpOn |
◆ JumpToStep
| string realvirtual.LogicStep_JumpOnSignal.JumpToStep |
◆ Signal
| Signal realvirtual.LogicStep_JumpOnSignal.Signal |
