| bgImg (defined in realvirtual.HMI) | realvirtual.HMI | |
| CloseExtendedArea(Vector3 pos) (defined in realvirtual.HMI) | realvirtual.HMI | virtual |
| Color | realvirtual.HMI | |
| ColorMouseOver | realvirtual.HMI | |
| EventOnValueChanged | realvirtual.HMI | |
| FollowCamera | realvirtual.HMI_Text | |
| GetCanvas(GameObject HMIelement, ref RectTransform rectTransform) (defined in realvirtual.HMI) | realvirtual.HMI | |
| GetImage(string objName) (defined in realvirtual.HMI) | realvirtual.HMI | |
| GetText(string objName) (defined in realvirtual.HMI) | realvirtual.HMI | |
| Init() (defined in realvirtual.HMI_Text) | realvirtual.HMI_Text | virtual |
| ObjectTracking | realvirtual.HMI_Text | |
| Offset | realvirtual.HMI_Text | |
| OnTransformParentChanged() (defined in realvirtual.HMI) | realvirtual.HMI | |
| OnValueChanged() (defined in realvirtual.HMI) | realvirtual.HMI | |
| SignalActivateInformation (defined in realvirtual.HMI_Text) | realvirtual.HMI_Text | |
| Text | realvirtual.HMI_Text | |
| TextFontSize | realvirtual.HMI_Text | |
| TrackedObject | realvirtual.HMI_Text | |
| UpdateUISkinParameter(RealvirtualUISkin skin) (defined in realvirtual.HMI) | realvirtual.HMI | |
