| bgImg (defined in realvirtual.HMI) | realvirtual.HMI | |
| ButtonText | realvirtual.HMI_Switch | |
| CloseExtendedArea(Vector3 pos) (defined in realvirtual.HMI) | realvirtual.HMI | virtual |
| Color | realvirtual.HMI | |
| ColorMouseOver | realvirtual.HMI | |
| ColorOn | realvirtual.HMI_Switch | |
| EventOnValueChanged | realvirtual.HMI | |
| GetCanvas(GameObject HMIelement, ref RectTransform rectTransform) (defined in realvirtual.HMI) | realvirtual.HMI | |
| GetImage(string objName) (defined in realvirtual.HMI) | realvirtual.HMI | |
| GetText(string objName) (defined in realvirtual.HMI) | realvirtual.HMI | |
| Init() (defined in realvirtual.HMI_Switch) | realvirtual.HMI_Switch | virtual |
| IsOn (defined in realvirtual.HMI_Switch) | realvirtual.HMI_Switch | |
| OnPointerEnter(PointerEventData eventData) (defined in realvirtual.HMI_Switch) | realvirtual.HMI_Switch | |
| OnPointerExit(PointerEventData eventData) (defined in realvirtual.HMI_Switch) | realvirtual.HMI_Switch | |
| OnTransformParentChanged() (defined in realvirtual.HMI) | realvirtual.HMI | |
| OnValueChanged() (defined in realvirtual.HMI) | realvirtual.HMI | |
| SignalInit | realvirtual.HMI_Switch | |
| SignalOn | realvirtual.HMI_Switch | |
| TextSize | realvirtual.HMI_Switch | |
| ToggleChanged(bool value) (defined in realvirtual.HMI_Switch) | realvirtual.HMI_Switch | |
| UpdateUISkinParameter(RealvirtualUISkin skin) (defined in realvirtual.HMI) | realvirtual.HMI | |
