Controls camera following of a specific GameObject, can be triggered by buttons or other UI elements. More...
| void | StartFollowing () |
| Starts continuous camera following of the target object. | |
| void | StopFollowing () |
| Stops continuous camera following. | |
| void | FocusOnObject () |
| Performs a one-time camera movement to focus on the target object. | |
| void | ToggleFollowing () |
| Toggles between following and not following. | |
| bool | IsFollowing () |
| Returns true if currently following the target object. | |
| void | SetObjectToFollow (GameObject obj, bool startImmediately=false) |
| Sets the target object to follow and optionally starts following immediately. | |
| void | SetLerpSpeed (float speed) |
| Sets the lerp speed for camera following (can be called during runtime) Lower values (0.1-0.5) create smooth cinematic motion Medium values (0.5-2.0) provide balanced tracking Higher values (2.0-10.0) create tight, responsive tracking. | |
| GameObject | ObjectToFollow |
| The GameObject to follow or focus on. | |
| bool | UseCustomDistance |
| If true, uses the specified Distance value instead of auto-calculating based on bounds. | |
| float | Distance |
| Camera distance from the object in meters. | |
| bool | UseCustomViewAngle |
| If true, uses the specified ViewAngle instead of auto-selecting. | |
| Vector3 | ViewAngle |
| Camera rotation in degrees. | |
| bool | AllowRotation |
| If true, user can orbit camera around the object while keeping it centered. | |
| bool | AllowZoom |
| If true, user can adjust distance from the object while following. | |
| bool | AutoStartFollowing |
| If true, automatically starts following on enable. | |
| float | LerpSpeed |
| Lerp speed multiplier for smooth camera motion. | |
| bool | SmoothStart |
| Enable smooth transition when starting to follow. | |
| bool | StopOnMouseClick |
| Stop following when user clicks any mouse button. | |
| bool | ShowStopButton |
| Show UI button to stop camera focus during following. | |
| GameObject | StopButtonPrefab |
| Optional custom prefab for stop button, if null uses default from Resources. | |
| PLCInputBool | PLCSignalStartFollowing |
| PLC signal to control following (true = follow, false = stop) | |
| bool | FollowActive |
| Public bool to control following state. | |
Provides both one-time focus and continuous following modes with optional user control over rotation and zoom. The camera follows the object's pivot point (transform.position) for predictable behavior. When distance is auto-calculated, it uses the object's bounds to ensure the entire object fits in view.
Usage:
- Attach to a UI button or any GameObject
- Set the ObjectToFollow property to the target GameObject
- Configure follow options (distance, rotation, zoom)
- Call StartFollowing(), StopFollowing(), or FocusOnObject() from button events
◆ FocusOnObject()
| void realvirtual.CameraFollowObject.FocusOnObject | ( | ) |
The camera will move to view the object's pivot point but will not continuously track it. Distance is calculated from object bounds if not specified to ensure the whole object fits in view. Can be called directly from button OnClick events.
◆ IsFollowing()
| bool realvirtual.CameraFollowObject.IsFollowing | ( | ) |
◆ SetLerpSpeed()
| void realvirtual.CameraFollowObject.SetLerpSpeed | ( | float | speed | ) |
◆ SetObjectToFollow()
| void realvirtual.CameraFollowObject.SetObjectToFollow | ( | GameObject | obj, |
| bool | startImmediately = false |
◆ StartFollowing()
| void realvirtual.CameraFollowObject.StartFollowing | ( | ) |
The camera will follow the object's pivot point (transform.position) and keep it centered. Distance is calculated from object bounds if not specified to ensure the whole object fits in view. Can be called directly from button OnClick events.
◆ StopFollowing()
| void realvirtual.CameraFollowObject.StopFollowing | ( | ) |
Camera returns to normal user-controlled navigation. Can be called directly from button OnClick events.
◆ ToggleFollowing()
| void realvirtual.CameraFollowObject.ToggleFollowing | ( | ) |
If currently following, stops. If not following, starts. Useful for toggle buttons.
◆ AllowRotation
| bool realvirtual.CameraFollowObject.AllowRotation |
◆ AllowZoom
| bool realvirtual.CameraFollowObject.AllowZoom |
◆ AutoStartFollowing
| bool realvirtual.CameraFollowObject.AutoStartFollowing |
◆ Distance
| float realvirtual.CameraFollowObject.Distance |
◆ FollowActive
| bool realvirtual.CameraFollowObject.FollowActive |
◆ LerpSpeed
| float realvirtual.CameraFollowObject.LerpSpeed |
◆ ObjectToFollow
| GameObject realvirtual.CameraFollowObject.ObjectToFollow |
◆ PLCSignalStartFollowing
| PLCInputBool realvirtual.CameraFollowObject.PLCSignalStartFollowing |
◆ ShowStopButton
| bool realvirtual.CameraFollowObject.ShowStopButton |
◆ SmoothStart
| bool realvirtual.CameraFollowObject.SmoothStart |
◆ StopButtonPrefab
| GameObject realvirtual.CameraFollowObject.StopButtonPrefab |
◆ StopOnMouseClick
| bool realvirtual.CameraFollowObject.StopOnMouseClick |
◆ UseCustomDistance
| bool realvirtual.CameraFollowObject.UseCustomDistance |
◆ UseCustomViewAngle
| bool realvirtual.CameraFollowObject.UseCustomViewAngle |
◆ ViewAngle
| Vector3 realvirtual.CameraFollowObject.ViewAngle |
