| GetAbsDirection(float abspositon) | realvirtual.BasePath | |
| GetAbsPosition(float abspositon, ref BasePath currentpath) | realvirtual.BasePath | |
| GetDirection(float normalizedposition) | realvirtual.BasePath | |
| GetLength() | realvirtual.BasePath | |
| GetLocalDirection(float normalizedposition) | realvirtual.BasePath | |
| GetPosition(float normalizedposition, ref BasePath currentpath) | realvirtual.BasePath | |
