realvirtual.BlendShapeFrame Struct Reference
A blend shape frame. More...
| BlendShapeFrame (float frameWeight, Vector3[] deltaVertices, Vector3[] deltaNormals, Vector3[] deltaTangents) | |
| Creates a new blend shape frame. | |
| float | FrameWeight |
| The weight of the blend shape frame. | |
| Vector3[] | DeltaVertices |
| The delta vertices of the blend shape frame. | |
| Vector3[] | DeltaNormals |
| The delta normals of the blend shape frame. | |
| Vector3[] | DeltaTangents |
| The delta tangents of the blend shape frame. | |
Constructor & Destructor Documentation
◆ BlendShapeFrame()
| realvirtual.BlendShapeFrame.BlendShapeFrame | ( | float | frameWeight, |
| Vector3[] | deltaVertices, | ||
| Vector3[] | deltaNormals, | ||
| Vector3[] | deltaTangents | ||
- Parameters
frameWeight The weight of the blend shape frame. deltaVertices The delta vertices of the blend shape frame. deltaNormals The delta normals of the blend shape frame. deltaTangents The delta tangents of the blend shape frame.
◆ DeltaNormals
| Vector3 [] realvirtual.BlendShapeFrame.DeltaNormals |
◆ DeltaTangents
| Vector3 [] realvirtual.BlendShapeFrame.DeltaTangents |
◆ DeltaVertices
| Vector3 [] realvirtual.BlendShapeFrame.DeltaVertices |
◆ FrameWeight
| float realvirtual.BlendShapeFrame.FrameWeight |
