| ResetColor(GameObject obj) (defined in realvirtual.realvirtualUI) | realvirtual.realvirtualUI | |
| SetColor(GameObject obj, Color color) (defined in realvirtual.realvirtualUI) | realvirtual.realvirtualUI | |
