| ButtonOn | realvirtual.UIButton | |
| ButtonText | realvirtual.UIButton | |
| color | realvirtual.UIButton | |
| IsOn (defined in realvirtual.UIButton) | realvirtual.UIButton | |
| IsToggle (defined in realvirtual.UIButton) | realvirtual.UIButton | |
| NormallyOpenend | realvirtual.UIButton | |
| OnMouseDown() (defined in realvirtual.UIButton) | realvirtual.UIButton | |
| OnMouseUp() (defined in realvirtual.UIButton) | realvirtual.UIButton | |
| ResetColor(GameObject obj) (defined in realvirtual.realvirtualUI) | realvirtual.realvirtualUI | |
| SetColor(GameObject obj, Color color) (defined in realvirtual.realvirtualUI) | realvirtual.realvirtualUI | |
