| OnPointerClick(PointerEventData eventData) (defined in realvirtual.ToggleButton) | realvirtual.ToggleButton | |
| OnPointerEnter(PointerEventData eventData) (defined in realvirtual.ToggleButton) | realvirtual.ToggleButton | |
| OnPointerExit(PointerEventData eventData) (defined in realvirtual.ToggleButton) | realvirtual.ToggleButton | |
| ResetColor(GameObject obj) (defined in realvirtual.realvirtualUI) | realvirtual.realvirtualUI | |
| SetColor(GameObject obj, Color color) (defined in realvirtual.realvirtualUI) | realvirtual.realvirtualUI | |
| SetToggleOff(string buttonname) (defined in realvirtual.ToggleButton) | realvirtual.ToggleButton | |
| SetToggleOn(string buttonname) (defined in realvirtual.ToggleButton) | realvirtual.ToggleButton | |
