Unified state statistics tracking system for components. More...
| void | Initialize (bool? useDESTime=null, Func< double > customTimeFunc=null) |
| Initialize the statistics system. | |
| void | SetState (string newState) |
| Set a new state by name. | |
| void | SetState (Enum enumState) |
| Set a new state from an enum value. | |
| string | GetCurrentState () |
| Get the current state name. | |
| void | UpdateStatistics () |
| Lightweight statistics update. | |
| void | FlushInspectorStats () |
| Forces a full rebuild of inspector-visible lists. | |
| float | GetUtilization01 () |
| Get utilization as a value between 0 and 1. | |
| float | GetUtilizationPercent () |
| Get utilization as a percentage (0-100). | |
| float | GetStatePercentage (string state) |
| Get the percentage of time spent in a specific state. | |
| float | GetStateDuration (string state) |
| Get the duration spent in a specific state. | |
| Dictionary< string, float > | GetAllStatePercentages () |
| Get all state percentages as a dictionary. | |
| float | GetTotalTime () |
| Get total tracked time. | |
| void | StatReset () |
| Reset all statistics. Implements IStatReset interface. | |
| string | GetDisplay () |
| Get formatted display string for statistics. Implements IStatDisplay interface. | |
| bool | IsFreeState (string state) |
| Check if a state is considered "free" (non-utilized). P10: O(1) via HashSet. | |
| void | AddFreeState (string state) |
| Add a state to the free states list. | |
| void | RemoveFreeState (string state) |
| Remove a state from the free states list. | |
| void | SetStateColor (string stateName, Color color) |
| Set a custom color for a specific state. | |
| Color | GetStateColor (string stateName, Color defaultColor) |
| Get the color for a specific state. | |
| bool | HasStateColor (string stateName) |
| Check if a custom color has been set for a state. | |
| void | ClearStateColors () |
| Clear all custom state colors. | |
| string | GetDetailedReport () |
| Get a detailed report of all statistics. | |
Tracks time spent in different states, calculates utilization, and provides visualization data. Can be used by both regular components (using Time.time) and DES components (using DES.Now). Performance-optimized: 0 GC allocations in hot path. Inspector lists updated lazily on demand.
◆ AddFreeState()
| void realvirtual.StateStatistics.AddFreeState | ( | string | state | ) |
◆ ClearStateColors()
| void realvirtual.StateStatistics.ClearStateColors | ( | ) |
◆ FlushInspectorStats()
| void realvirtual.StateStatistics.FlushInspectorStats | ( | ) |
Call only when display is needed (e.g., editor repaint, gizmo draw, report generation, end of simulation).
◆ GetAllStatePercentages()
| Dictionary< string, float > realvirtual.StateStatistics.GetAllStatePercentages | ( | ) |
P8: Still allocates a new dictionary (unavoidable for this API), but no UpdateStatistics cascade.
◆ GetCurrentState()
| string realvirtual.StateStatistics.GetCurrentState | ( | ) |
◆ GetDetailedReport()
| string realvirtual.StateStatistics.GetDetailedReport | ( | ) |
◆ GetDisplay()
| string realvirtual.StateStatistics.GetDisplay | ( | ) |
Implements realvirtual.IStatDisplay.
◆ GetStateColor()
| Color realvirtual.StateStatistics.GetStateColor | ( | string | stateName, |
| Color | defaultColor | ||
- Parameters
stateName The name of the state defaultColor The default color to use if no custom color is set
- Returns
- The color for this state
◆ GetStateDuration()
| float realvirtual.StateStatistics.GetStateDuration | ( | string | state | ) |
P7: Calculates directly from raw data - no UpdateStatistics cascade, 0 GC.
- Parameters
state The state name to query
- Returns
- Time spent in that state (seconds)
◆ GetStatePercentage()
| float realvirtual.StateStatistics.GetStatePercentage | ( | string | state | ) |
P6: Calculates directly from raw data - no UpdateStatistics cascade, 0 GC.
- Parameters
- Returns
- Percentage of time in that state (0-100)
◆ GetTotalTime()
| float realvirtual.StateStatistics.GetTotalTime | ( | ) |
◆ GetUtilization01()
| float realvirtual.StateStatistics.GetUtilization01 | ( | ) |
◆ GetUtilizationPercent()
| float realvirtual.StateStatistics.GetUtilizationPercent | ( | ) |
◆ HasStateColor()
| bool realvirtual.StateStatistics.HasStateColor | ( | string | stateName | ) |
- Parameters
- Returns
- True if a custom color exists for this state
◆ Initialize()
| void realvirtual.StateStatistics.Initialize | ( | bool? | useDESTime = null, |
| Func< double > | customTimeFunc = null |
- Parameters
useDESTime If true, uses DES.Now for time tracking. If false, uses Time.time. If null, auto-detects. customTimeFunc Optional custom function to get current time
◆ IsFreeState()
| bool realvirtual.StateStatistics.IsFreeState | ( | string | state | ) |
◆ RemoveFreeState()
| void realvirtual.StateStatistics.RemoveFreeState | ( | string | state | ) |
◆ SetState() [1/2]
| void realvirtual.StateStatistics.SetState | ( | Enum | enumState | ) |
- Parameters
enumState The enum value representing the new state
◆ SetState() [2/2]
| void realvirtual.StateStatistics.SetState | ( | string | newState | ) |
Lightweight: just records elapsed time, no inspector rebuild.
- Parameters
newState The name of the new state
◆ SetStateColor()
| void realvirtual.StateStatistics.SetStateColor | ( | string | stateName, |
| Color | color | ||
- Parameters
stateName The name of the state color The color to use for this state in visualizations
◆ StatReset()
| void realvirtual.StateStatistics.StatReset | ( | ) |
Implements realvirtual.IStatReset.
◆ UpdateStatistics()
| void realvirtual.StateStatistics.UpdateStatistics | ( | ) |
Marks dirty for lazy inspector rebuild. No GC allocations. Call freely from hot paths.
