| void | MoveCursorTo (rvUIContent content) |
| Moves the cursor to a specific UI content element. | |
| void | MoveCursor (int n) |
| Moves the cursor by n steps in the tree hierarchy. | |
| void | StepIn () |
| Steps into the current container by moving cursor to its first child. | |
| void | StepOut () |
| Steps out of the current container by moving cursor to the parent container. | |
| void | RefreshFromCursor () |
| Refreshes layout from cursor to root using bottom-up approach. | |
| void | Add (ContentType type) |
| Adds a new UI content element at the cursor position and updates cursor to the new element. | |
| rvUIToggleGroup | AddToggleGroup (bool allowSwitchOff=false, bool autoassignButtons=false) |
| rvUIToggleGroup | AddToggleGroup (rvUIContent content, bool allowSwitchOff=false, bool autoassignButtons=false) |
| void | Clear () |
| Clears all content from the container where cursor is located. | |
| rvUIFloatingMenuPanel | AddSubMenu (SubMenuType subMenuType, realvirtual.rvUIRelativePlacement.Placement placement, float margin=10f) |
| Creates a submenu (rvUIFloatingMenuPanel) for the current cursor content. | |
| rvUIMenuButton | AddButton (string text) |
| Creates a button with the specified text and returns it for event wiring. | |
| rvUIDropdown | AddDropdown () |
| rvUITooltip | AddTooltip (string text, RectTransform parent, rvUIRelativePlacement.Placement placement) |
| rvUIToggleDropdown | AddToggleDropdown () |
| rvUIGenericInputField | AddInputField (TMP_InputField.ContentType contentType) |
| rvUIMenuSpacing | AddSpace () |
| rvUIMenuButton | AddButton (string text, Sprite icon, rvUIToggleGroup toggleGroup=null) |
| Creates a button with the specified text and icon and returns it for event wiring. | |
| rvUIMenuButton | AddButton (string text, string materialIcon, rvUIToggleGroup toggleGroup=null) |
| rvUIText | AddText (string text, bool keepRefreshing=true) |
| Creates a text element with the specified content and returns it. | |
| rvUIContainer | AddContainer (ContentType type) |
| Creates a container and returns it for adding children. | |
| rvUIFloatingMenuPanel | AddVerticalBox () |
| rvUIFloatingMenuPanel | AddHorizontalBox () |
| EnumField< T > | AddEnumField< T > (string label, T initialValue, bool useHorizontalLayout=true) |
| Creates a generic enum field with button group for selecting values. | |
| rvUIMenuWindow | AddMenuWindow (rvUIMenuSettings settings) |
| Creates an adaptive menu window that can switch between horizontal, vertical, and window styles. | |
| rvUIMenuButton | ButtonPrefab |
| Prefab for creating button UI elements. | |
| rvUIDropdown | DropdownPrefab |
| Prefab for creating dropdown menu UI elements. | |
| rvUIMenuSpacing | SpacingPrefab |
| Prefab for creating spacing elements between UI components. | |
| rvUIText | TextPrefab |
| Prefab for creating text label UI elements. | |
| rvUIToggleDropdown | ToggleDropdownPrefab |
| rvUIGenericInputField | InputFieldPrefab |
| rvUITooltip | TooltipPrefab |
| rvUIMenuWindow | WindowPrefab |
| Prefab for creating menu window containers with title bar and styling. | |
| rvUIFloatingMenuPanel | EmptyWindowPrefab |
| Prefab for creating empty floating window containers. | |
| rvUIFloatingMenuPanel | EmptyHorizontalPrefab |
| Prefab for creating horizontal layout containers. | |
| rvUIFloatingMenuPanel | EmptyVerticalPrefab |
| Prefab for creating vertical layout containers. | |
| ColorScheme | colorScheme |
| rvUIContent | cursor |
| Current cursor position in the UI tree. | |
Properties | |
| static RuntimeUIBuilder | Instance [get] |
| Singleton instance of the RuntimeUIBuilder. | |
◆ Add()
| void realvirtual.RuntimeUIBuilder.Add | ( | ContentType | type | ) |
Automatically triggers layout refresh from the new content to root. Works in both edit mode and play mode.
- Parameters
type The type of content to create
◆ AddButton() [1/2]
| rvUIMenuButton realvirtual.RuntimeUIBuilder.AddButton | ( | string | text | ) |
- Parameters
text The button text
- Returns
- The created button component
◆ AddButton() [2/2]
| rvUIMenuButton realvirtual.RuntimeUIBuilder.AddButton | ( | string | text, |
| Sprite | icon, | ||
| rvUIToggleGroup | toggleGroup = null |
- Parameters
text The button text icon The button icon sprite
- Returns
◆ AddContainer()
| rvUIContainer realvirtual.RuntimeUIBuilder.AddContainer | ( | ContentType | type | ) |
- Parameters
type The type of container to create
- Returns
- The created container
◆ AddEnumField< T >()
| EnumField< T > realvirtual.RuntimeUIBuilder.AddEnumField< T > | ( | string | label, |
| T | initialValue, | ||
| bool | useHorizontalLayout = true |
Returns EnumField for event wiring and value management.
- Template Parameters
T Enum type
- Parameters
label Label text initialValue Initial enum value useHorizontalLayout True for horizontal layout, false for vertical
- Returns
- The created EnumField instance
- Type Constraints
T : System.Enum
◆ AddMenuWindow()
| rvUIMenuWindow realvirtual.RuntimeUIBuilder.AddMenuWindow | ( | rvUIMenuSettings | settings | ) |
Content is preserved when switching styles.
- Parameters
initialStyle The initial style for the window
- Returns
- The created rvUIMenuWindow instance
◆ AddSubMenu()
| rvUIFloatingMenuPanel realvirtual.RuntimeUIBuilder.AddSubMenu | ( | SubMenuType | subMenuType, |
| realvirtual::rvUIRelativePlacement::Placement | placement, | ||
| float | margin = 10f |
The submenu is placed in the top-level root container and uses rvUIRelativePlacement to position itself relative to the cursor content.
- Parameters
subMenuType The type of submenu panel to create placement The relative placement type (Above, Below, Left, Right, Horizontal, Vertical) margin The margin distance from the target
- Returns
- The created submenu container, or null if creation failed
◆ AddText()
| rvUIText realvirtual.RuntimeUIBuilder.AddText | ( | string | text, |
| bool | keepRefreshing = true |
- Parameters
text The text content
- Returns
- The created text component
◆ Clear()
| void realvirtual.RuntimeUIBuilder.Clear | ( | ) |
If cursor is a container, clears its children. Otherwise, clears siblings in parent container. After clearing, moves cursor to the container.
◆ MoveCursor()
| void realvirtual.RuntimeUIBuilder.MoveCursor | ( | int | n | ) |
Negative values move backward (previous siblings/parent), positive values move forward (next siblings/children).
- Parameters
n Number of steps to move (+ or -)
◆ MoveCursorTo()
| void realvirtual.RuntimeUIBuilder.MoveCursorTo | ( | rvUIContent | content | ) |
- Parameters
content The target UI content to move cursor to
◆ RefreshFromCursor()
| void realvirtual.RuntimeUIBuilder.RefreshFromCursor | ( | ) |
This ensures layout changes propagate correctly from modified elements up to the root container. Each node in the path is refreshed individually without re-refreshing children (avoids redundant work).
◆ StepIn()
| void realvirtual.RuntimeUIBuilder.StepIn | ( | ) |
Only works if cursor is a container with children.
◆ StepOut()
| void realvirtual.RuntimeUIBuilder.StepOut | ( | ) |
◆ ButtonPrefab
| rvUIMenuButton realvirtual.RuntimeUIBuilder.ButtonPrefab |
◆ cursor
| rvUIContent realvirtual.RuntimeUIBuilder.cursor |
All Add operations insert content at this location.
◆ DropdownPrefab
| rvUIDropdown realvirtual.RuntimeUIBuilder.DropdownPrefab |
◆ EmptyHorizontalPrefab
| rvUIFloatingMenuPanel realvirtual.RuntimeUIBuilder.EmptyHorizontalPrefab |
◆ EmptyVerticalPrefab
| rvUIFloatingMenuPanel realvirtual.RuntimeUIBuilder.EmptyVerticalPrefab |
◆ EmptyWindowPrefab
| rvUIFloatingMenuPanel realvirtual.RuntimeUIBuilder.EmptyWindowPrefab |
◆ SpacingPrefab
| rvUIMenuSpacing realvirtual.RuntimeUIBuilder.SpacingPrefab |
◆ TextPrefab
| rvUIText realvirtual.RuntimeUIBuilder.TextPrefab |
◆ WindowPrefab
| rvUIMenuWindow realvirtual.RuntimeUIBuilder.WindowPrefab |
Property Documentation
◆ Instance
staticget |
Only one instance should exist in the scene.
