| CallbackSettingsWindow(Component component, Property property, object value) (defined in realvirtual.RuntimePersistence) | realvirtual.RuntimePersistence | |
| DeletePersistences() (defined in realvirtual.RuntimePersistence) | realvirtual.RuntimePersistence | |
| InitAwake() (defined in realvirtual.RuntimePersistence) | realvirtual.RuntimePersistence | |
| LoadBeforeAwake (defined in realvirtual.RuntimePersistence) | realvirtual.RuntimePersistence | |
| LoadPersistences() (defined in realvirtual.RuntimePersistence) | realvirtual.RuntimePersistence | |
| OnBeforeAwake() (defined in realvirtual.RuntimePersistence) | realvirtual.RuntimePersistence | |
| OnOptionsWindowClosing (defined in realvirtual.RuntimePersistence) | realvirtual.RuntimePersistence | |
| PropertiesToSave (defined in realvirtual.RuntimePersistence) | realvirtual.RuntimePersistence | |
| SaveOnDisable (defined in realvirtual.RuntimePersistence) | realvirtual.RuntimePersistence | |
| SavePersistences() (defined in realvirtual.RuntimePersistence) | realvirtual.RuntimePersistence | |
