OPC UA client interface for connecting to OPC UA servers used in industrial automation. More...
| bool | Connect () |
| Connects to the OPCUA Server. | |
| OPCUA_Node | GetOPCUANode (string nodeid) |
| Gets an OPCUA_Node with the NodeID in all the Childrens of the Interface. | |
| void | ImportNodes () |
| Imports all OPCUANodes under TopNodeId and creates GameObjects. | |
| void | EditorImportNodes () |
| void | ImportNodes (string nodeid) |
| Imports all nodes under one TopNodeID. | |
| OPCUANodeSubscription | Subscribe (string nodeid, NodeUpdateDelegate del) |
| Subscribes to an OPCUA node, delegate function gets called when node value is updated on OPCUA server. | |
| object | ReadNodeValue (OPCUA_Node node) |
| Reads a Node value and returns it as object. | |
| object | ReadNodeValue (string nodeid) |
| Reads a Node value based on its id and returns it as object. | |
| object | ReadNodeValue (string nodeid, ref string status) |
| Reads a Node value based on its id and returns it as object, a status reference is passed. | |
| bool | WriteNodeValue (string nodeid, object value) |
| Writes a value to an OPCUA node with its nodeid. | |
| bool | WriteNodeValue (OPCUA_Node node, object value) |
| Writes a value to an OPCUA node with its node object. | |
| bool | WriteNodeValue (string nodeid, object value, ref string status) |
| Writes a value to an OPCUA node with its node id and a status variable reference. | |
| void | UnSubscribe (OPCUANodeSubscription subscription) |
| void | Disconnect () |
| Disconnects from the OPCUA server. | |
Provides secure communication with industrial equipment and control systems through the OPC Unified Architecture protocol. Supports multiple security policies, certificate-based authentication, and automatic reconnection. This interface enables reading and writing process data from/to OPC UA servers like KEPServerEX, Siemens WinCC OA, or embedded OPC UA servers in PLCs. Configure the server connection parameters and security settings to establish communication with your OPC UA server.
◆ Connect()
| bool realvirtual.OPCUA_Interface.Connect | ( | ) |
◆ Disconnect()
| void realvirtual.OPCUA_Interface.Disconnect | ( | ) |
◆ GetOPCUANode()
| OPCUA_Node realvirtual.OPCUA_Interface.GetOPCUANode | ( | string | nodeid | ) |
◆ ImportNodes() [1/2]
| void realvirtual.OPCUA_Interface.ImportNodes | ( | ) |
If GameObject with NodeID is already existing the GameObject will be updated. Does not deletes any Nodes. If Realvirtual Framework is existent (Compiler Switch REALVIRTUAL) also Realvirtual PLCInputs and PLCOutputs are created or updated or all nodes with suitable data types.
◆ ImportNodes() [2/2]
| void realvirtual.OPCUA_Interface.ImportNodes | ( | string | nodeid | ) |
Folder
Variable
◆ ReadNodeValue() [1/3]
| object realvirtual.OPCUA_Interface.ReadNodeValue | ( | OPCUA_Node | node | ) |
◆ ReadNodeValue() [2/3]
| object realvirtual.OPCUA_Interface.ReadNodeValue | ( | string | nodeid | ) |
◆ ReadNodeValue() [3/3]
| object realvirtual.OPCUA_Interface.ReadNodeValue | ( | string | nodeid, |
| ref string | status | ||
◆ Subscribe()
| OPCUANodeSubscription realvirtual.OPCUA_Interface.Subscribe | ( | string | nodeid, |
| NodeUpdateDelegate | del | ||
◆ WriteNodeValue() [1/3]
| bool realvirtual.OPCUA_Interface.WriteNodeValue | ( | OPCUA_Node | node, |
| object | value | ||
◆ WriteNodeValue() [2/3]
| bool realvirtual.OPCUA_Interface.WriteNodeValue | ( | string | nodeid, |
| object | value | ||
◆ WriteNodeValue() [3/3]
| object | value, | ||
