Utility class for Mitsubishi device address parsing, validation, and mapping Handles all standard Mitsubishi device types and address formats. More...
| static string int address | ParseDeviceAddress (string device) |
| static bool | IsValidDeviceAddress (string deviceType, int address) |
| Validates if a device address is valid for the specified device type. | |
| static Type | GetDataTypeForDevice (string deviceType) |
| Gets the appropriate data type for a device. | |
| static SignalType | GetSignalTypeForDevice (string deviceType) |
| Gets signal type for realvirtual based on device type. | |
| static SignalDirection | GetDefaultDirection (string deviceType) |
| Determines the appropriate signal direction based on device type (from PLC perspective) | |
| static bool | IsReadOnlyDevice (string deviceType) |
| Checks if device type is read-only. | |
| static bool | IsBitDevice (string deviceType) |
| Checks if device type uses bit addressing. | |
| static DeviceTypeInfo | GetDeviceInfo (string deviceType) |
| Gets device type information. | |
| static string | FormatDeviceAddress (string deviceType, int address, bool useHex=false) |
| Formats a device address for display. | |
| static int | OctalToDecimal (int octalAddress) |
| Converts octal address to decimal (for X, Y devices) | |
| static int | DecimalToOctal (int decimalAddress) |
| Converts decimal address to octal (for X, Y devices) | |
| static string int int address | ParseFileRegisterAddress (string device) |
| static List< string > | GetSupportedDeviceTypes () |
| Gets all supported device types. | |
| static List< string > | GetDeviceTypesByCategory (DeviceCategory category) |
| Gets device types filtered by category. | |
| static Dictionary< string, List< int > > | GroupAddressesForBatching (List<(string device, string address)> devices) |
| Groups device addresses for optimal batch reading. | |
| static int | GetWordCount (Type dataType) |
| Calculates the number of words needed for a data type. | |
Static Public Attributes | |
| static string | deviceType |
| Parses a device address string into device type and numeric address. | |
| static string int | blockNumber |
◆ DecimalToOctal()
static |
◆ FormatDeviceAddress()
static |
◆ GetDataTypeForDevice()
static |
◆ GetDefaultDirection()
static |
◆ GetDeviceInfo()
static |
◆ GetDeviceTypesByCategory()
static |
◆ GetSignalTypeForDevice()
static |
◆ GetSupportedDeviceTypes()
static |
◆ GetWordCount()
static |
◆ GroupAddressesForBatching()
static |
◆ IsBitDevice()
static |
◆ IsReadOnlyDevice()
static |
◆ IsValidDeviceAddress()
static |
◆ OctalToDecimal()
static |
◆ deviceType
static |
Parses a file register address (e.g., "R0\100" or "ZR1000")
