Enables keyboard-controlled movement of GameObjects with smooth interpolation and axis limits. More...
| void | ResetToInitialPosition () |
| Resets the GameObject to its initial position. | |
| float | Speed |
| Movement speed in meters per second. | |
| float | LerpFactor |
| Lerp smoothing factor - higher values provide more responsive movement. | |
| KeyCode | XNegativeKey1 |
| Primary key for negative X axis movement. | |
| KeyCode | XNegativeKey2 |
| Secondary key for negative X axis movement (optional) | |
| KeyCode | XPositiveKey1 |
| Primary key for positive X axis movement. | |
| KeyCode | XPositiveKey2 |
| Secondary key for positive X axis movement (optional) | |
| KeyCode | YNegativeKey1 |
| Primary key for negative Y axis movement. | |
| KeyCode | YNegativeKey2 |
| Secondary key for negative Y axis movement (optional) | |
| KeyCode | YPositiveKey1 |
| Primary key for positive Y axis movement. | |
| KeyCode | YPositiveKey2 |
| Secondary key for positive Y axis movement (optional) | |
| KeyCode | ZNegativeKey1 |
| Primary key for negative Z axis movement. | |
| KeyCode | ZNegativeKey2 |
| Secondary key for negative Z axis movement (optional) | |
| KeyCode | ZPositiveKey1 |
| Primary key for positive Z axis movement. | |
| KeyCode | ZPositiveKey2 |
| Secondary key for positive Z axis movement (optional) | |
| KeyCode | ResetKey |
| Key to reset GameObject to initial position. | |
| Vector2 | XAxisLimits |
| Minimum and maximum X axis position limits in meters. | |
| Vector2 | YAxisLimits |
| Minimum and maximum Y axis position limits in meters. | |
| Vector2 | ZAxisLimits |
| Minimum and maximum Z axis position limits in meters. | |
KeyboardMove provides precise manual control over GameObject positioning using configurable keyboard inputs. It supports smooth lerped movement, customizable speed settings, and position limits for each axis. This component is ideal for manual positioning tasks, debugging object placement, and creating interactive control systems for automation simulations.
Key Features:
- Independent control of X, Y, and Z axes with dual-key support
- Smooth lerped movement with adjustable smoothing factor
- Position limits for constraining movement within defined boundaries
- Local space movement respecting object rotation
- Visual gizmos showing movement boundaries in Scene view
Common Applications:
- Manual positioning of robots or machinery during setup
- Debug tool for testing object placement
- Interactive control for demonstration scenarios
- Fine-tuning object positions in virtual commissioning
Integration Points:
- Can be combined with Drive components for hybrid control
- Works alongside physics-based movement systems
- Supports runtime enabling/disabling for mode switching
For detailed documentation see: https://doc.realvirtual.io/components-and-scripts/scene-interaction/keyboard-move
◆ ResetToInitialPosition()
| void realvirtual.KeyboardMove.ResetToInitialPosition | ( | ) |
◆ LerpFactor
| float realvirtual.KeyboardMove.LerpFactor |
◆ ResetKey
| KeyCode realvirtual.KeyboardMove.ResetKey |
◆ Speed
| float realvirtual.KeyboardMove.Speed |
◆ XAxisLimits
| Vector2 realvirtual.KeyboardMove.XAxisLimits |
◆ XNegativeKey1
| KeyCode realvirtual.KeyboardMove.XNegativeKey1 |
◆ XNegativeKey2
| KeyCode realvirtual.KeyboardMove.XNegativeKey2 |
◆ XPositiveKey1
| KeyCode realvirtual.KeyboardMove.XPositiveKey1 |
◆ XPositiveKey2
| KeyCode realvirtual.KeyboardMove.XPositiveKey2 |
◆ YAxisLimits
| Vector2 realvirtual.KeyboardMove.YAxisLimits |
◆ YNegativeKey1
| KeyCode realvirtual.KeyboardMove.YNegativeKey1 |
◆ YNegativeKey2
| KeyCode realvirtual.KeyboardMove.YNegativeKey2 |
◆ YPositiveKey1
| KeyCode realvirtual.KeyboardMove.YPositiveKey1 |
◆ YPositiveKey2
| KeyCode realvirtual.KeyboardMove.YPositiveKey2 |
◆ ZAxisLimits
| Vector2 realvirtual.KeyboardMove.ZAxisLimits |
◆ ZNegativeKey1
| KeyCode realvirtual.KeyboardMove.ZNegativeKey1 |
◆ ZNegativeKey2
| KeyCode realvirtual.KeyboardMove.ZNegativeKey2 |
◆ ZPositiveKey1
| KeyCode realvirtual.KeyboardMove.ZPositiveKey1 |
◆ ZPositiveKey2
| KeyCode realvirtual.KeyboardMove.ZPositiveKey2 |
