realvirtual.KebaWriteVarsResponse Class Reference
Response structure for write_vars command (StatusResponse in API spec) More...
Classes | |
| class | KebaError |
| Error structure. More... | |
| int | GetRequestId () |
| Gets the actual request ID regardless of field name. | |
| int | request |
| Request ID that this responds to (some responses use "request") | |
| int | response |
| Request ID that this responds to (some responses use "response") | |
| int | status |
| HTTP status code (200 = OK) | |
| KebaWriteVarResult[] | result |
| Results for each variable (not "data", but "result" per API spec) | |
| KebaError | error |
| Error details if status is not 200. | |
Class Documentation
◆ realvirtual::KebaWriteVarsResponse::KebaError
| class realvirtual::KebaWriteVarsResponse::KebaError |
◆ GetRequestId()
| int realvirtual.KebaWriteVarsResponse.GetRequestId | ( | ) |
◆ error
| KebaError realvirtual.KebaWriteVarsResponse.error |
◆ request
| int realvirtual.KebaWriteVarsResponse.request |
◆ response
| int realvirtual.KebaWriteVarsResponse.response |
◆ result
| KebaWriteVarResult [] realvirtual.KebaWriteVarsResponse.result |
◆ status
| int realvirtual.KebaWriteVarsResponse.status |
