realvirtual.Global Member List
This is the complete list of members for realvirtual.Global, including all inherited members.
| AddComponentIfNotExisting< T >(GameObject gameobject) (defined in realvirtual.Global) | realvirtual.Global | static |
| AddGameObjectIfNotExisting(string name, GameObject parent=null) (defined in realvirtual.Global) | realvirtual.Global | static |
| Build (defined in realvirtual.Global) | realvirtual.Global | static |
| CalculateCenterpoint(Vector3 A, Vector3 B, Vector3 C) (defined in realvirtual.Global) | realvirtual.Global | static |
| CheckDrives(Drive[] drives, string CheckedBy, int minnumber) (defined in realvirtual.Global) | realvirtual.Global | static |
| CreateTexture(Color32 color) (defined in realvirtual.Global) | realvirtual.Global | static |
| DebugArrow(Vector3 position, Vector3 direction, float duration=0) (defined in realvirtual.Global) | realvirtual.Global | static |
| DebugArrow(Vector3 position, Vector3 direction, Color color, float duration=0) (defined in realvirtual.Global) | realvirtual.Global | static |
| DebugDrawArrow(Vector3 position, Vector3 direction, Color color, float duration=0, bool depthTest=true) (defined in realvirtual.Global) | realvirtual.Global | static |
| DebugGlobalAxis(Vector3 position, float duration=0, Color color=default(Color)) (defined in realvirtual.Global) | realvirtual.Global | static |
| DebugGlobalPoint(Vector3 position, Color color, float duration=0) (defined in realvirtual.Global) | realvirtual.Global | static |
| DebugLocalAxis(Vector3 position, float duration=0, GameObject gameObject=null) (defined in realvirtual.Global) | realvirtual.Global | static |
| DestroyComponents< T >(GameObject gameobject) (defined in realvirtual.Global) | realvirtual.Global | static |
| DestroyObjectsByComponent< T >(GameObject parent) (defined in realvirtual.Global) | realvirtual.Global | static |
| g4acontrollernotnull (defined in realvirtual.Global) | realvirtual.Global | static |
| GatherObjects(GameObject root) (defined in realvirtual.Global) | realvirtual.Global | static |
| GetAllDerivedTypes(this System.AppDomain aAppDomain, System.Type aType) (defined in realvirtual.Global) | realvirtual.Global | static |
| GetAllPrefabsAtPathWithComponent< T >(string Folder) (defined in realvirtual.Global) | realvirtual.Global | static |
| GetAllSceneComponents< T >() (defined in realvirtual.Global) | realvirtual.Global | static |
| GetAllWithGroup(string group) (defined in realvirtual.Global) | realvirtual.Global | static |
| GetAllWithGroupIncludingSub(string group) (defined in realvirtual.Global) | realvirtual.Global | static |
| GetComponentAlsoInactive< T >(GameObject parent) (defined in realvirtual.Global) | realvirtual.Global | static |
| GetComponentByName< T >(GameObject parent, string name) (defined in realvirtual.Global) | realvirtual.Global | static |
| GetComponentsAlsoInactive< T >(GameObject parent) (defined in realvirtual.Global) | realvirtual.Global | static |
| GetComponentsByName< T >(GameObject parent, string name) (defined in realvirtual.Global) | realvirtual.Global | static |
| GetDESTime() | realvirtual.Global | static |
| GetGameObjectByName(string name, GameObject parent=null) (defined in realvirtual.Global) | realvirtual.Global | static |
| GetGroups() (defined in realvirtual.Global) | realvirtual.Global | static |
| GetPath(GameObject go) (defined in realvirtual.Global) | realvirtual.Global | static |
| GetRootComponent< T >() (defined in realvirtual.Global) | realvirtual.Global | static |
| GetTotalBounds(GameObject root) (defined in realvirtual.Global) | realvirtual.Global | static |
| GetTotalCenter(GameObject root) (defined in realvirtual.Global) | realvirtual.Global | static |
| IncrementVersion() (defined in realvirtual.Global) | realvirtual.Global | static |
| Initialize() (defined in realvirtual.Global) | realvirtual.Global | static |
| IsDESMode | realvirtual.Global | static |
| IsDESPackageAvailable | realvirtual.Global | static |
| IsExcludedViewType | realvirtual.Global | static |
| IsGame4AutomationTypeIncluded(GameObject target) (defined in realvirtual.Global) | realvirtual.Global | static |
| IsGame4AutomationViewTypeIncluded(GameObject target) (defined in realvirtual.Global) | realvirtual.Global | static |
| MovePositionKeepChildren(GameObject root, Vector3 deltalocalposition) (defined in realvirtual.Global) | realvirtual.Global | static |
| MoveRotationKeepChildren(GameObject root, Quaternion deltarotation) (defined in realvirtual.Global) | realvirtual.Global | static |
| QuickEditDisplay (defined in realvirtual.Global) | realvirtual.Global | static |
| realvirtualcontroller (defined in realvirtual.Global) | realvirtual.Global | static |
| Release (defined in realvirtual.Global) | realvirtual.Global | static |
| RoundVector(Vector3 vector, int decimalPlaces) (defined in realvirtual.Global) | realvirtual.Global | static |
| RuntimeInspectorEnabled (defined in realvirtual.Global) | realvirtual.Global | static |
| SetActiveIncludingSubObjects(GameObject parent, bool active) (defined in realvirtual.Global) | realvirtual.Global | static |
| SetActiveSubObjects(GameObject parent, bool active) (defined in realvirtual.Global) | realvirtual.Global | static |
| SetG4AController(realvirtualController controller) (defined in realvirtual.Global) | realvirtual.Global | static |
| SetPositionKeepChildren(GameObject root, Vector3 globalposition) (defined in realvirtual.Global) | realvirtual.Global | static |
| SetRotationKeepChildren(GameObject root, Quaternion rotation) (defined in realvirtual.Global) | realvirtual.Global | static |
| SetVersion() (defined in realvirtual.Global) | realvirtual.Global | static |
| Version (defined in realvirtual.Global) | realvirtual.Global | static |
