| ActivateOnClick (defined in realvirtual.GenericButton) | realvirtual.GenericButton | |
| ActivateOnOff (defined in realvirtual.GenericButton) | realvirtual.GenericButton | |
| ActivateOnOn (defined in realvirtual.GenericButton) | realvirtual.GenericButton | |
| ActiveImageOnOn (defined in realvirtual.GenericButton) | realvirtual.GenericButton | |
| EventOnClick (defined in realvirtual.GenericButton) | realvirtual.GenericButton | |
| ImageOff (defined in realvirtual.GenericButton) | realvirtual.GenericButton | |
| ImageOn (defined in realvirtual.GenericButton) | realvirtual.GenericButton | |
| IsOn (defined in realvirtual.GenericButton) | realvirtual.GenericButton | |
| IsPressed (defined in realvirtual.GenericButton) | realvirtual.GenericButton | |
| ResetColor(GameObject obj) (defined in realvirtual.realvirtualUI) | realvirtual.realvirtualUI | |
| SetColor(Color color) (defined in realvirtual.GenericButton) | realvirtual.GenericButton | |
| SetColor(GameObject obj, Color color) (defined in realvirtual.realvirtualUI) | realvirtual.realvirtualUI | |
| SetStatus(bool ison) (defined in realvirtual.GenericButton) | realvirtual.GenericButton | |
