realvirtual.GLBStreamingImporter Class Reference
Performs true asynchronous GLB import with incremental loading to avoid blocking the main thread. More...
| GLBStreamingImporter (string path, MonoBehaviour contextObject=null, Transform parentTransform=null) | |
| async Task< GameObject > | ImportAsync (Action< GLBLoadProgress > onProgress=null, CancellationToken token=default) |
| Imports a GLB file with true async processing and progress reporting. | |
Uses coroutines to spread heavy operations across multiple frames for smooth runtime experience.
◆ ImportAsync()
| async Task< GameObject > realvirtual.GLBStreamingImporter.ImportAsync | ( | Action< GLBLoadProgress > | onProgress = null, |
| CancellationToken | token = default |
Uses coroutines to spread heavy operations across multiple frames.
