Security and validation utilities for GLB import/export operations Provides path validation, type whitelisting, and safe null checking.
More...
| static bool | IsValidExportPath (string path, out string sanitizedPath) |
| | Validates and sanitizes a file export path Returns true if the path is valid, with sanitized path in the out parameter.
| static bool | IsValidFileName (string filename, out string sanitizedFileName) |
| | Validates a filename for export.
| static bool | IsAllowedComponentType (Type type) |
| | Validates if a type is safe to instantiate during import Prevents arbitrary code execution through malicious GLB files.
| static bool | IsAllowedTypeName (string typeName) |
| | Validates if a type name is safe before attempting to resolve it.
| static bool | IsNullOrDestroyed (UnityEngine.Object obj) |
| | Safe null check for Unity objects that handles destroyed objects Prevents MissingReferenceException.
| static bool | IsTransformNullOrDestroyed (Transform transform) |
| | Safe null check for Transform specifically.
| static T | ParseEnumSafe< T > (string value, T defaultValue) |
| | Safe enum parsing that returns default value on failure.
| static Type | ResolveTypeCached (string typeName) |
| | Cached type resolution for performance Searches all assemblies only once per type name.
| static void | ClearTypeCache () |
| | Clears the type resolution cache Call this when assemblies are reloaded.
◆ ClearTypeCache()
| static void realvirtual.GLBSecurityUtilities.ClearTypeCache |
static |
◆ IsAllowedComponentType()
| static bool realvirtual.GLBSecurityUtilities.IsAllowedComponentType |
Type |
type | ) |
static |
◆ IsAllowedTypeName()
| static bool realvirtual.GLBSecurityUtilities.IsAllowedTypeName |
string |
typeName | ) |
static |
◆ IsNullOrDestroyed()
| static bool realvirtual.GLBSecurityUtilities.IsNullOrDestroyed |
UnityEngine::Object |
obj | ) |
static |
◆ IsTransformNullOrDestroyed()
| static bool realvirtual.GLBSecurityUtilities.IsTransformNullOrDestroyed |
Transform |
transform | ) |
static |
◆ IsValidExportPath()
| static bool realvirtual.GLBSecurityUtilities.IsValidExportPath |
string |
path, |
out string |
sanitizedPath |
static |
◆ IsValidFileName()
| static bool realvirtual.GLBSecurityUtilities.IsValidFileName |
string |
filename, |
out string |
sanitizedFileName |
static |
◆ ParseEnumSafe< T >()
| static T realvirtual.GLBSecurityUtilities.ParseEnumSafe< T > |
string |
value, |
T |
defaultValue |
static |
◆ ResolveTypeCached()
| static Type realvirtual.GLBSecurityUtilities.ResolveTypeCached |
string |
typeName | ) |
static |
