Central manager behaviour for the DistanceFinder system that enables/disables based on usage (Pro). More...
| static void | Enable () |
| Manually enable the manager. | |
| static void | Disable () |
| Manually disable the manager. | |
| bool | EnableConnectionHighlight |
| Enable highlighting when connections are established. | |
| bool | HighlightOnStart |
| Highlight initial connections when the scene starts. | |
| bool | HighlightBothObjects |
| Highlight both connector and connectable. | |
| Color | ConnectionColor |
| Color for connection highlights (green with 30% transparency) | |
| Color | DisconnectionColor |
| Color for disconnection highlights (red with 30% transparency) | |
| float | ConnectionHighlightDuration |
| Duration of connection highlight in seconds. | |
| float | DisconnectionHighlightDuration |
| Duration of disconnection highlight in seconds. | |
| bool | ShowDebugInfo |
| Show debug information in console. | |
| bool | DrawGizmos |
| Draw gizmos for connections in scene view. | |
| Color | GizmoConnectionColor |
| Color for connection gizmos. | |
| bool | AutoDisableWhenEmpty |
| Automatically disable this manager when no connections exist. | |
| float | AutoDisableDelay |
| Delay before auto-disabling when no connections (seconds) | |
| float | EditorUpdateRate |
| Update rate in editor mode (seconds) | |
| int | ActiveConnections |
| int | RegisteredConnectors |
| int | RegisteredConnectables |
| bool | IsActive |
Properties | |
| static DistanceSystem | Instance [get] |
| Gets or creates the singleton instance. | |
This component is automatically created when needed and disables itself when not in use to save performance.
◆ Disable()
static |
◆ Enable()
static |
◆ AutoDisableDelay
| float realvirtual.DistanceSystem.AutoDisableDelay |
◆ AutoDisableWhenEmpty
| bool realvirtual.DistanceSystem.AutoDisableWhenEmpty |
◆ ConnectionColor
| Color realvirtual.DistanceSystem.ConnectionColor |
◆ ConnectionHighlightDuration
| float realvirtual.DistanceSystem.ConnectionHighlightDuration |
◆ DisconnectionColor
| Color realvirtual.DistanceSystem.DisconnectionColor |
◆ DisconnectionHighlightDuration
| float realvirtual.DistanceSystem.DisconnectionHighlightDuration |
◆ DrawGizmos
| bool realvirtual.DistanceSystem.DrawGizmos |
◆ EditorUpdateRate
| float realvirtual.DistanceSystem.EditorUpdateRate |
◆ EnableConnectionHighlight
| bool realvirtual.DistanceSystem.EnableConnectionHighlight |
◆ GizmoConnectionColor
| Color realvirtual.DistanceSystem.GizmoConnectionColor |
◆ HighlightBothObjects
| bool realvirtual.DistanceSystem.HighlightBothObjects |
◆ HighlightOnStart
| bool realvirtual.DistanceSystem.HighlightOnStart |
◆ ShowDebugInfo
| bool realvirtual.DistanceSystem.ShowDebugInfo |
Property Documentation
◆ Instance
staticget |
