Static helper class for finding components based on distance. More...
| static T | GetNearest< T > (Vector3 position) |
| Finds the nearest component of type T from the specified position. | |
| static T | GetNearest< T > (Transform from) |
| Finds the nearest component of type T from the specified transform. | |
| static T | GetNearest< T > (Vector3 position, float maxDistance) |
| Finds the nearest component of type T within the specified maximum distance. | |
| static T | GetNearestIncludingChildren< T > (Vector3 position) |
| Finds the nearest component of type T from the specified position, including in children. | |
| static T | GetNearestIncludingChildren< T > (Transform from) |
| Finds the nearest component of type T from the specified transform, including in children. | |
| static T | GetNearestIncludingChildren< T > (Vector3 position, float maxDistance) |
| Finds the nearest component of type T within the specified maximum distance, including in children. | |
| static Component | GetNearestIncludingChildren (Vector3 position, float maxDistance, Type componentType) |
| Finds the nearest component of specific type within the specified maximum distance, including in children. | |
| static List< T > | GetNearestMultiple< T > (Vector3 position, int count) |
| Finds the N nearest components of type T from the specified position. | |
| static List< T > | GetNearestMultipleIncludingChildren< T > (Vector3 position, int count) |
| Finds the N nearest components of type T from the specified position, including in children. | |
| static List< T > | GetNearestMultiple< T > (Vector3 position, int count, float maxDistance) |
| Finds the N nearest components of type T within the specified maximum distance. | |
| static List< T > | GetNearestMultipleIncludingChildren< T > (Vector3 position, int count, float maxDistance) |
| Finds the N nearest components of type T within the specified maximum distance, including in children. | |
| static List< T > | GetAllInRadius< T > (Vector3 position, float radius) |
| Finds all components of type T within the specified radius. | |
| static List< T > | GetAllInRadiusIncludingChildren< T > (Vector3 position, float radius) |
| Finds all components of type T within the specified radius, including in children. | |
| static DistanceTarget | GetNearest (Vector3 position, string typeIdentifier) |
| Finds the nearest DistanceTarget with the specified type identifier. | |
| static DistanceTarget | GetNearest (Vector3 position, string typeIdentifier, float maxDistance) |
| Finds the nearest DistanceTarget with the specified type identifier within maximum distance. | |
| static List< DistanceTarget > | GetAllInRadius (Vector3 position, float radius, string typeIdentifier) |
| Finds all DistanceTarget components with the specified type identifier within radius. | |
| static bool | ExistsInRadius< T > (Vector3 position, float radius) |
| Checks if a component of type T exists within the specified radius. | |
| static float | GetDistanceToNearest< T > (Vector3 position) |
| Gets the distance to the nearest component of type T, returns -1 if none found. | |
| static void | ForceRefresh () |
| Forces a refresh of all DistanceTarget components (useful in editor) | |
Works with components marked with DistanceTarget. Provides spatial queries to find nearest components of specific types in both editor and runtime.
◆ ExistsInRadius< T >()
static |
- Type Constraints
T : Component
◆ ForceRefresh()
static |
◆ GetAllInRadius()
static |
◆ GetAllInRadius< T >()
static |
- Type Constraints
T : Component
◆ GetAllInRadiusIncludingChildren< T >()
static |
- Type Constraints
T : Component
◆ GetDistanceToNearest< T >()
static |
- Type Constraints
T : Component
◆ GetNearest() [1/2]
static |
◆ GetNearest() [2/2]
static |
◆ GetNearest< T >() [1/3]
static |
- Type Constraints
T : Component
◆ GetNearest< T >() [2/3]
static |
- Type Constraints
T : Component
◆ GetNearest< T >() [3/3]
static |
- Type Constraints
T : Component
◆ GetNearestIncludingChildren()
static |
◆ GetNearestIncludingChildren< T >() [1/3]
static |
- Type Constraints
T : Component
◆ GetNearestIncludingChildren< T >() [2/3]
static |
- Type Constraints
T : Component
◆ GetNearestIncludingChildren< T >() [3/3]
static |
- Type Constraints
T : Component
◆ GetNearestMultiple< T >() [1/2]
static |
- Type Constraints
T : Component
◆ GetNearestMultiple< T >() [2/2]
static |
- Type Constraints
T : Component
◆ GetNearestMultipleIncludingChildren< T >() [1/2]
static |
- Type Constraints
T : Component
◆ GetNearestMultipleIncludingChildren< T >() [2/2]
static |
- Type Constraints
T : Component
