| AllowEntry(PathMover pathMover) (defined in realvirtual.BaseStation) | realvirtual.BaseStation | protectedvirtual |
| areameshrenderer (defined in realvirtual.BaseStation) | realvirtual.BaseStation | protected |
| CurrentPathMover (defined in realvirtual.BaseStation) | realvirtual.BaseStation | |
| Dimension (defined in realvirtual.BaseStation) | realvirtual.BaseStation | |
| LimitToTransportablesonPath (defined in realvirtual.BaseStation) | realvirtual.BaseStation | protected |
| OnAtPositon(PathMover pathMover) (defined in realvirtual.BaseStation) | realvirtual.BaseStation | protectedvirtual |
| OnExit(PathMover pathMover) (defined in realvirtual.BaseStation) | realvirtual.BaseStation | protectedvirtual |
| OnFixedUpdate() (defined in realvirtual.BaseStation) | realvirtual.BaseStation | protectedvirtual |
| OnFullyStopped(SimulationPath path, PathMover mover) (defined in realvirtual.BaseStation) | realvirtual.BaseStation | |
| OnTriggerEnter(Collider other) (defined in realvirtual.BaseStation) | realvirtual.BaseStation | |
| OnTriggerExit(Collider other) (defined in realvirtual.BaseStation) | realvirtual.BaseStation | |
| OpenEntry(PathMover pathmover) (defined in realvirtual.BaseStation) | realvirtual.BaseStation | |
| PathMoverMovingIn (defined in realvirtual.BaseStation) | realvirtual.BaseStation | protected |
| PathMoverMovingOut (defined in realvirtual.BaseStation) | realvirtual.BaseStation | protected |
| PathMoverWaitingForEntry (defined in realvirtual.BaseStation) | realvirtual.BaseStation | protected |
| Release() (defined in realvirtual.BaseStation) | realvirtual.BaseStation | |
| SettingChanged() (defined in realvirtual.BaseStation) | realvirtual.BaseStation | |
| transportablewaitingforentry (defined in realvirtual.BaseStation) | realvirtual.BaseStation | protected |
