Axis defines the kinematic and physical movement axis for drives and kinematic systems. More...
Public Types | |
| enum | AxisPositionTypes { None , Pivot , BoundingBoxCenter , RadiusCenter } |
| void | SignalSubDriveAxis (Axis subAxis, bool added) |
| Signals this axis when a sub-drive axis is added or removed from the hierarchy. | |
| void | removeSecondaryAxis (GameObject obj) |
| Removes a secondary axis from this axis's list of secondary axes. | |
| void | DisplayGroupMeshes (Color color, bool forcecolor=false) |
| Displays wireframe meshes for all objects in the same kinematic group with the specified color. | |
| void | AlignToReference () |
| Aligns this axis to the position and rotation of the AxisReferenceGameObject. | |
| void | AxisDelete () |
| Deletes this axis and all connected secondary axes from the hierarchy. | |
| void | OnDestroy () |
| void | Break (bool breaking) |
| Enables or disables the breaking (locking) of this axis movement. | |
| Converts a DIRECTION enum value to its corresponding Vector3 direction. | |
| Determines if the given direction represents linear movement (returns true) or rotational movement (returns false). | |
| GameObject | AxisReferenceGameObject |
| Reference game object that defines the axis position and orientation. | |
| bool | Balljoint |
| Indicates if this is a ball joint axis allowing rotation in all directions. | |
| bool | IsSecondaryAxis |
| Indicates if this axis is a secondary axis in a kinematic chain. | |
| AxisPositionTypes | PositionMode |
| Defines how the axis position is calculated (Pivot, BoundingBoxCenter, or RadiusCenter) | |
| DIRECTION | Direction |
| The movement direction of this axis (LinearX/Y/Z or RotationX/Y/Z) | |
| Vector3 | RotationOffset |
| Rotation offset applied to the axis in degrees. | |
| bool | DrawGizmos |
| Enables or disables the visual gizmos for this axis in the Scene view. | |
| float | GizmoDistance |
| Distance in meters for displaying the axis gizmo. | |
| Vector3 | axisReferencePosition |
| The reference position of the axis in world coordinates. | |
| bool | UseLimits |
| Enables position or rotation limits for this axis. | |
| float | LowerLimit |
| Lower limit position in millimeters for linear axes or degrees for rotational axes. | |
| float | UpperLimit |
| Upper limit position in millimeters for linear axes or degrees for rotational axes. | |
| float | LimitEndPosWindow |
| Window in millimeters or degrees for detecting when the axis reaches its limits. | |
| bool | OnLowerLimit |
| Indicates if the axis is currently at its lower limit. | |
| bool | OnUppperLimit |
| Indicates if the axis is currently at its upper limit. | |
| Vector3 | AnchorPos |
| The anchor position for the physical joint in world coordinates. | |
| Vector3 | LocalAnchorPos |
| The anchor position for the physical joint in local coordinates. | |
| Vector3 | ConnectedLocalAnchorPos |
| The connected anchor position in local coordinates of the connected body. | |
| float | AxisGizmoSize |
| Size multiplier for the axis gizmo visualization. | |
| GameObject | ConnectedAxis |
| The connected axis GameObject in the kinematic chain. | |
| float | Position |
| Current position in millimeters for linear axes or degrees for rotational axes. | |
| string | icon |
| Color | MeshColor |
| Color | AxisColor |
| bool | activeInKinTool |
| List< GameObject > | secondaryAxis |
| List of secondary axes connected to this axis. | |
| Axis | parentAxis |
| List< Axis > | SubDriveAxises |
| List of sub-drive axes controlled by this axis. | |
It specifies the movement direction, limits, and physical joint properties for both linear and rotational movements. Axes can be hierarchically connected to create complex kinematic chains for robotic systems.
◆ AlignToReference()
| void realvirtual.Axis.AlignToReference | ( | ) |
◆ AxisDelete()
| void realvirtual.Axis.AxisDelete | ( | ) |
◆ Break()
| void realvirtual.Axis.Break | ( | bool | breaking | ) |
◆ DirectionIsLinear()
static |
◆ DirectionToVector()
| Vector3 realvirtual.Axis.DirectionToVector | ( | DIRECTION | direction | ) |
◆ DisplayGroupMeshes()
| void realvirtual.Axis.DisplayGroupMeshes | ( | Color | color, |
| bool | forcecolor = false |
◆ removeSecondaryAxis()
| void realvirtual.Axis.removeSecondaryAxis | ( | GameObject | obj | ) |
◆ SignalSubDriveAxis()
| void realvirtual.Axis.SignalSubDriveAxis | ( | Axis | subAxis, |
| bool | added | ||
◆ AnchorPos
| Vector3 realvirtual.Axis.AnchorPos |
◆ AxisGizmoSize
| float realvirtual.Axis.AxisGizmoSize |
◆ AxisReferenceGameObject
| GameObject realvirtual.Axis.AxisReferenceGameObject |
◆ axisReferencePosition
| Vector3 realvirtual.Axis.axisReferencePosition |
◆ Balljoint
| bool realvirtual.Axis.Balljoint |
◆ ConnectedAxis
| GameObject realvirtual.Axis.ConnectedAxis |
◆ ConnectedLocalAnchorPos
| Vector3 realvirtual.Axis.ConnectedLocalAnchorPos |
◆ Direction
| DIRECTION realvirtual.Axis.Direction |
◆ DrawGizmos
| bool realvirtual.Axis.DrawGizmos |
◆ GizmoDistance
| float realvirtual.Axis.GizmoDistance |
◆ IsSecondaryAxis
| bool realvirtual.Axis.IsSecondaryAxis |
◆ LimitEndPosWindow
| float realvirtual.Axis.LimitEndPosWindow |
◆ LocalAnchorPos
| Vector3 realvirtual.Axis.LocalAnchorPos |
◆ LowerLimit
| float realvirtual.Axis.LowerLimit |
◆ OnLowerLimit
| bool realvirtual.Axis.OnLowerLimit |
◆ OnUppperLimit
| bool realvirtual.Axis.OnUppperLimit |
◆ Position
| float realvirtual.Axis.Position |
◆ PositionMode
| AxisPositionTypes realvirtual.Axis.PositionMode |
◆ RotationOffset
| Vector3 realvirtual.Axis.RotationOffset |
◆ secondaryAxis
| List<GameObject> realvirtual.Axis.secondaryAxis |
◆ SubDriveAxises
| List<Axis> realvirtual.Axis.SubDriveAxises |
◆ UpperLimit
| float realvirtual.Axis.UpperLimit |
◆ UseLimits
| bool realvirtual.Axis.UseLimits |
