| BuildAuthUrl(string baseUrl, int httpPort) | realvirtual.KebaTools | static |
| BuildVariablesUrl(string baseUrl, int httpPort, string path, bool recursive) | realvirtual.KebaTools | static |
| BuildWebSocketUrl(string baseUrl, int webSocketPort, string authToken) | realvirtual.KebaTools | static |
| CreateAddToTopicArgs(string topicName, KebaTopicVariable[] variables, bool addNotFoundVars=true) | realvirtual.KebaTools | static |
| CreateSignalMetadata(KebaVariable variable) | realvirtual.KebaTools | static |
| CreateSignalMetadata(string variableName, string dataType, object value=null) | realvirtual.KebaTools | static |
| CreateSubscribeTopicArgs(string topicName, int cycleTimeMs=DEFAULT_SUBSCRIPTION_CYCLE_MS, string protocol="default") | realvirtual.KebaTools | static |
| CreateTopicArgs(string topicName) | realvirtual.KebaTools | static |
| CreateTopicVariable(string variableName, bool onChange=true) | realvirtual.KebaTools | static |
| CreateUnsubscribeTopicArgs(string topicName) | realvirtual.KebaTools | static |
| CreateWebSocketMessage(int requestId, string command, object args) | realvirtual.KebaTools | static |
| CreateWriteVarsArgs(Dictionary< string, object > signalValues, Func< string, string > getKebaVarName) | realvirtual.KebaTools | static |
| CreateWriteVarsArgs(IEnumerable< Signal > signals) | realvirtual.KebaTools | static |
| DEFAULT_CONNECTION_TIMEOUT | realvirtual.KebaTools | static |
| DEFAULT_HTTP_PORT | realvirtual.KebaTools | static |
| DEFAULT_SUBSCRIPTION_CYCLE_MS | realvirtual.KebaTools | static |
| DEFAULT_TOKEN_LIFETIME | realvirtual.KebaTools | static |
| DEFAULT_WEBSOCKET_PORT | realvirtual.KebaTools | static |
| FormatErrorMessage(string operation, string error) | realvirtual.KebaTools | static |
| FormatLogMessage(string operation, string details) | realvirtual.KebaTools | static |
| GetCleanSignalName(string kebaVariableName) | realvirtual.KebaTools | static |
| GetKebaDataType(Signal signal) | realvirtual.KebaTools | static |
| GetKebaVariableName(Signal signal) | realvirtual.KebaTools | static |
| GetSupportedKebaTypes() | realvirtual.KebaTools | static |
| IsKebaTypeSupported(string kebaType) | realvirtual.KebaTools | static |
| IsValidKebaVariablePath(string path) | realvirtual.KebaTools | static |
| MapKebaTypeToSignalType(string kebaType) | realvirtual.KebaTools | static |
| MapSignalTypeToKebaType(SignalType signalType) | realvirtual.KebaTools | static |
| TOKEN_REFRESH_MARGIN | realvirtual.KebaTools | static |
| ValidateConnectionParameters(string baseUrl, int httpPort, int webSocketPort, string username, string password, out string errorMessage) | realvirtual.KebaTools | static |
| ValidateTopicParameters(string topicName, int cycleTimeMs, out string errorMessage) | realvirtual.KebaTools | static |
